Question about Panasonic PT-47WX53 47" Rear Projection HDTV
My Panasonic 1080i is not turning on i press power the green light turns on but the screen stays black. then eventually the light turns red. another website instructed me to order STK392-110 some chip piece that I'm supposed to solder to the mother board? Is this right? Thanks, Roland
  • rbedregal Oct 08, 2009
    Panasonic HDTV when I try to turn it on the green light blinks steadly and after about a minute it turns read and nothing ever happens no picture no light on the screen. What is the propblem?
    Panasonic Hdtv 1080i pt-43lc14 When I press power the green light starts blinking for about 1 minute then it turns red the lamp light also blinks red. The tv sounds like it wants to work but there is no picture nor sound. the TV makes a little noise but no atcual sound coming from the TV. The screen remains black. Please help.
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
First, if the convergence chips are bad or shorted the set will shut down and the power light will blink three times in a sequence--if no three blinks I would suggest another possible problem common to this set.
Before the set shuts off do you see anything at all on the screen after a minute or two? A strange band of noise from top to bottom on the right side? The more information you can give me the better the chance I can tell you exactly what is wrong---I have fixed hundreds of these sets--
I am here to help--give me all the information you can
SD TECH
Posted on Oct 08, 2009
  • 1 more comment
  • SD Tech
    SD Tech Oct 08, 2009
    By the way--please confirm actual model number of this TV---Pt-47wx53?
  • SD Tech
    JUST a question? how many opinions do you want to your problem? No one can help if you do not reply to questions----good luck to you.
  • SD Tech
    the other person---this set does not have an inverter board-shows you what kind of answer you get for poor questions
    President:
  • 2,923 Answers
Roland,
STK392-110 is a Convergence IC that is responsible if there's NO picture but there's a sound coming out from the TV.
BUT if there's no picture and no sound, then you need to check or replace the Inverter board and not the convergence IC.
Check the link below so that you could see how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=inverter+board
Have a great day!
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
The TV will not turn on
transister on tube blew out, needs new tube, could be from storm
Jul 01, 2009 | Panasonic CT-30WC14 30" TV
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
242 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
