Question about Frigidaire FDB1502RGC Built-in Dishwasher
Hi, m'y dishwasher do not fully drain after is cycle, look like the installation is good and the glass filter is clean (Buyed new in june)
  • kbsmiles309 May 11, 2010
    Approx how much water is left to be drained?
  • 136 Answers
Make sure your dishwasher was installed level side to side and front to back check it with a torpeto level (that`s a small level about a foot long ) if it`s not level there are leveling feet on all 4 corners screw them up or down to get level
Posted on Oct 08, 2009
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher will not drain
Good Morning Gord, thank you for your post!
If your dishwasher is not draining, it could possibly have a clogged drain hose or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of your dishwasher designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. Place filter back in its location and run a complete cycle. If you continue to have water left in the sump and your dishwasher is making a grinding noise, then it is recommended to reach out to a professional to diagnose the drain motor. You can often locate a certified technician directly through the manufacturer website or in your local directory.
Best regards!
Nov 24, 2013 | Frigidaire FPHD2491KF Dishwasher
There is always water left in the drain at the bottom of the dishwasher, which gets sprayed back on the dishes so now my glasses have material on them and it gets baked on in the dry cycle....
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jul 20, 2011 | Siemens SL85A705UC 24 in. Built-in...
My kelvinator dishwasher kd14ss leaves stains in my glasses cups and small bowls in the upper rack after each wash. Never used to do it before - turned up the rinse and check the salt, but after each wash...
It sounds like you need to check the filters and clean them. It’s usually pretty simple to do but makes the dishwasher run like new. I think that it might be obstructed somewhere preventing it from being able to fully rinse the dishes. Is it draining all the water after the cycle has finished?
Feb 03, 2018 | Kelvinator Dishwashers
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't drain. I cleaned it, see no visible clogs in drain hose, and I installed a new pump. Didn't fix it
hi,you need to switch the machine off,open the door and inside at the bottom is your drain ,lift out the filters and get a screwdriver there should be one screw to undo,get a pair of pliers and pull out the part you unsrewd.........have a really good look and feel inside with your fingers ,should be something in there food/broken glass/ anything could be there...............................
Mar 24, 2009 | Dishwashers
Frigidaire FDB1502RGC Built-in Dishwasher Logo
163 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
