Question about Vacuums
The ON/OFF switch does not work. Unable to turn off vacuum without unplugging from wall. After removing handle, the ON/OFF switch is in ON position, but cannot be toggled to OFF position. Please assist. Thank you.
  • jdpaley64 Oct 08, 2009
    Hoover Self Propelled Vac Model# U6476-910.
  • Philip Gaut May 11, 2010
    Make and model of machine would be helpful...
    Problem Solver:
  • 18 Answers
Replace the switch. Part number 28161067
Posted on Oct 08, 2009
Central vacuum won't turn off when hose removed from wall socket
There is a switch somewhere close to where you plug in the hose. Check and see if the switch is stuck in the down position. If so, it will either need to be replaced or cleaned to allow the switch to raise to the off position.
Semper Fi,
Z
Aug 03, 2017 | Vacuums
Wont turn on
It sounds like the switch had disconnected its a easy fix just remove the screws in the handle around the switch and simply reconnect the wires to the switch. Be sure you unplug you vacuum before you work on it
Jan 17, 2014 | Oreck UPR014T XL Pro 14 Upright Vaccum...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
I just bought a Hoover Windtunnel upright with bag, #U6485100. When installing the handle there was tape over the top with instructions do no remove until assembled. After assembling (screwing in the...
Be sure the on/off button and the power drive button are both in the OFF position before installing the handle. The actual switch inside must also be in the OFF position.
Feb 27, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater brush
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
U6439-900 will not turn off by the level in the handle.
These switches go bad, best to just replace it. Could have a problem with the rod inside the handle.
Apr 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Levels/Settings
These height adjustments are designed so that they will not adjust when the handle is in the "back" position. This is so they will stay where they are set and not self-adjust while you are vacuuming. To change the setting, you need to return the handle to the upright position and the adjust the setting and the machine will go to that position when the handle is lowered.
Jan 25, 2008 | Hoover Elite Rewind Bagless Upright...
Unplugged while unit was on by mistake and now it will not turn off with switch
it sound like you have pulled the wire to tight and it has shorted the switch inside the vacuum, so the wires are connecting, to cure this unplug from power supply and remove the cover to the switch and relocate it into its slot where it should originally should go, of course the housing to which the switch locates may now be damaged, but you should be able to stop the wires from touching and this will let you work the vacuum properly
secure the cable again where it comes out of the machine
Oct 13, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Open Questions:
Vacuums Logo
125 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
