Question about Plumbing
I need to know how to wire 110 to 220 on a hayward sp-1605-z1 pump motor
  • kbsmiles309 May 11, 2010
    Are you talking about just the pump, or do you want info on switching it and wireing the breaker info also. Please advise
    Scholar:
  • 34 Answers
The Hayward superpump is factory set at 220.
If you need to convert it to 110, all you need to do is take a screwdriver and remove the cap on the back of the motor. There are three prongs in the motor and a black jumper. The jumper connection needs to be disconnected and moved from The top and middle postion prongs, to the middle and lower prong. The ground wire (green) still connects to the same spot (usually a green bolt grounding lug). If using a Haward SPX1250wa (110 Cord) connect it to the pump Black wire to black connector/White to white. The Hayward cord comes with pre-attached terminal connections that makes it easy to do.
Once the cap is re-attached you should be good to go.
Posted on Oct 08, 2009
How to change a front bearing on sp 1540 c pump
you cannot they dont sell bearings get number of pump and motor you will have to replace the motor if you can get it make sure to get the seals
Aug 03, 2014 | Hayward Pool & Spa
SP-1510-Z1-XEHC
bad motor on pump need a new one
Jul 06, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
Sp-1510-z1-xehc above ground DE filter. How much DE
the part number you listed has nothing to do with a DE filter. try again
Jun 23, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
I have a Hayward, A.O. Smith sp-1510-z1 xe8k3, 1 hp pump. It is not turning and is getting hot and started to smoke. Is there anything I can try before I replace it?
SEPERATE THE PUMP FROM THE MOTOR AND SEE IF THE PUMP TURNS FREELY IF IT DOES THEN THE MOTOR IS BAD IF IT IS HARD TO TURN THE PUMP PLUG IN MOTOR AND SEE IT IT NOW RUNS IF IT DOES ALL YOU HAVE TO DO IS REPLACE THE PUMP IF THEY SELL IT SPERATE GOOD LUCK
Oct 22, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
How do you replace the seal on a Hayward pump model sp-1615-z1-mbk
if seal leaking probably ruining seals replace whole pump
Sep 20, 2012 | Hayward Pool & Spa
Pump starts but then trips breaker ?
the pump motor has a short in it its pulling far to many amps thats why the trip pops out
Jul 30, 2010 | Hayward GO-KIT #2 HAYWARD SUPER II PUMP...
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Plumbing Logo
345 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
