Question about Pioneer DEH-P4100
I have a pioneer deh-4100. I recently tried to run the aux to play songs off of my phone. The signal is only coming out of the rear rt/lt speakers. The volume control does not effect this signal nor is it effected by the EQ control. So it sounds crappy and quiet. It also can be heard at same quiet volume on cd channel and tuner channel. Help
How to get rear speaker signal from aftermarket stereo
You can fade front to rear in the menu but its not switched it might be fully faded to the front
Aug 31, 2014 | Pioneer Deh-X6600bt Car Cd Receiver...
Why is bluetooth not available anymore
Is bluetooth on at your phone? Pair your phone again with unit, refer manual page 11.
Jul 29, 2014 | Pioneer Car Audio & Video
Adjust volume on bluetooth mini speaker PSNANO PS-38
Quoted from the instruction manual:
"+/>>'" In TF/Bluetooth mode when short press this button: next song; long press: Volume up. Don't work in AUX mode.
"'<<\-" In TF/Bluetooth mode when short press this button: previous song; long press: Volume down. Don't work in AUX mode.
">''" In TF mode, short press this button: Play/Pause; In Bluetooth mode, short press this button: Play/Pause/Answer/End/Cancel dial/Pair. In Bluetooth mode, double click: Last number redial; long press for 2 seconds: reject calls. In TF/AUX mode, press it will be TF card and AUX exchange.
Aug 04, 2013 | Lands Phones
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
Installed my Pioneer DEH-1100MP When radio is turned on display /tuner/aux comes up Can set stations etc but no sound With light tester to speaker wires there is power etc
Does your car have a Factory amp if so u need to find the blue wire ( on most cars) and either ground it out or and power to it, it should turn the speakers on for you to play
Sep 10, 2010 | Pioneer DEH-1100 CD Player
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Aux in runs only back speakers and no volume control
This also happened to me, I just replaced the cable and works fine now.
May 27, 2009 | Pioneer DEH-P3000 CD Player
No sound with iPod Adapter CD-IB100II in the DEH-P2900MP
on the radio and the adapter their is a spot for the cord that connects the two the ends have different colors on them it should be purple and black just make sure the colors are matched up if they are off it will still read all the info and say its playing but no sound will come out
Oct 15, 2008 | Pioneer DEH-P2900MP CD Receiver...
Pioneer DEH-P4100 Logo
195 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
