Question about Drills
I cant get the drill to open up to remove the bit. What do i do?
  • Charles Cronin May 11, 2010
    Are you using the correct Chuck Key?
  • Johnny
    Johnny May 11, 2010
    what model?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
Your chuck is jammed. You can use a punch that is the same size as the jaws and a small hammer. You can tap the jaws back with the punch ever so slightly. Tap on each jaw the same amount of times. Start on one jaw with one tap, then to the next, and then to the third. After tapping each try to turn the chuck to open. This will dislodge the jaws slighlty and you should be able to move it. Keep doing this until you can open the chuck or remove the bit. After removing the bit spray some lubricant into the chuck and work it back and forth the whole length of the jaws. If this does not work you can put the bit in a vise and use a rubber or soft end hammer to hit the chuck off the bit. In this case you will have to replace the chuck. There is probably a bad spot in the jaws that is stripped.
Posted on Oct 09, 2009
How to fix a out of round drill press chuck (ToolKraft 350B
The chuck could be threaded like an average power drill.
Respectable drill presses use a hollow quill shaft that is likely to be machined into a taper that is likely to be number 1, 2 or 3 Morse taper.
Morse taper drill bits are used a lot - the shank is tapered and will grip and drive when inserted into the quill with just a small force. When the bit is to be removed the quill is turned by hand until a slot in the quill lines up with a slot in the housing and a wedge-shaped steel tool is slid in and tapped breaking the taper fit.
Most such drill presses are supplied with a chuck for light duty drilling already mounted. The chuck is often a Jacobs type mounting by means of a Jacobs taper onto a Morse taper adaptor.
The adaptor is tapered at both ends - at the lower end the taper is steep and the chuck must be pressed on with some force. The upper end will have the same gentle taper of the Morse taper drill bits and is removed in the same way.
Using the chuck drilling is limited to the capacity of the chuck, typically 1/2" or 5/8" unless blacksmith's drill bits are used that have stepped shanks.
Morse taper drill bits will allow heavy duty drilling far in excess of the chuck capacity.
Hopefully your problem is caused by the chuck rather than a bent quill.
Dec 03, 2017 | Drills
Why cant i get my drill bit in my hammer drill?
the end either pulls out or pushes in to insert and remove drill bit
Dec 16, 2015 | Hitachi DH50MR Jackhammer
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
Sds bit snapped in my makita bhr200 chuck.on taking the drill apart,the chuck is on a gear rod,and wont allow me to push the chuck down
You have to remove the striker bolt from inside the spindle first. to do this remove the internal circlip (not always easy) then you can tap the striker bolt out and then press the broken bit out.
Mar 15, 2013 | Makita Drills
I having problem of drill bit would like to know how to remove drill bit
Make sure the chuck is loose then clamp the drill bit in the vice and give the drill a straight pull ,once its out then put some engine oil down the chuck and let it soak in ,not that fish oil spray stuff .
Dec 02, 2011 | Metabo 600661620 SBE660 12" 01000 03000...
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
411 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
