Question about Farmall Cub Tractor Radiator
I have a Farmall H and switch it over to a12volt system with a alternator with a built in regulator. I need a wiring diagram for this.
  • Dennis Key
    Dennis Key Aug 14, 2012
    You should beable this diagram. This alt. has a built-in too.
  • Farmall Master
  • 2,478 Answers
TRY THIS.I have a Farmall H and switch it over to a12volt - 12_4_2011_10_28_09_pm.jpg
Posted on Dec 04, 2011
  • danielcar164
    danielcar164 Aug 14, 2012
    I'm trying to find a diagram just like this but for a 140 farmall. but im trying this picture and hope it is helpfull Thanks!!!!
    Master:
  • 401 Answers
You can get your alternator shop to make it a one wire alternator, so really all you need is a positive wire and ground to the frame. I got to be honest, I have convert many of them back to a 6 volt system, I use to set the point in the regulator to a 8 volt and install a eight volt battery. I didn\'t have to change much as the light and coil worked fine with it. There is a lot of stuff to change out when you change over to 12 volt system. Either way its hard on your starter. good luck
Posted on Jan 03, 2015
    Scholar:
  • 57 Answers
My father used to have a Farmall H and it is a nice tractor. There is no wiring diagram for the built in alternator as it has no adjustment, it is preset. You will need to change your starter to a 12 volt starter, and if you have lights they will also need to be changed to 12 volt bulbs. I believe the tractor has a magneto so there is no modification there as it is independent and is not connected to the power. If it has a spark coil you will need a limiting resistor connected between your 12 volt power and spark coil. That is about it. I have rewired old Model As and a 37 Ford convertable to 12 Volt system and wired many trailers. I hope this helped and if I can assist you further please let me know.
Posted on Oct 08, 2009
What would cause the alternator to run hot on a 1949 farmall cub tractor
Sounds like your still running power thru the original regulator also. Disconnect the original system completely so that your running power directly from alternator's inboard regulator and to the battery. Nowhere else.
Aug 31, 2014 | Cars & Trucks
Alternator wiring diagram on farmall M tractor
from scratch... well are you using the factory style of alternator or something different as you didn't mention the age and it could be: 12 volt positive or negative ground, or, 6 volt positive or negative ground. Or do you have a starter/generator or ??? Further research suggest you have a generator which would mean you have a voltage regulator somewhere... SO please help us help you. We need to identify your system before we can help... Pictures would be great. Numbers would be good, type of battery would help...
Aug 29, 2014 | Garden
Farmall M alternator wiring diagram
http://binatani.com/wp-content/uploads/2011/08/International-Harvester-Farmall-M-alternator-conversion-schematic.jpg
Aug 29, 2014 | Cars & Trucks
Voltage regulator connector wiring diagram
The voltage regulator is built into the alternator.
Your alternator should use a plug that is molded into a 90 degree angle, has four holes and 3 pins.
A two wire connector fits an alternator made in the 70s and 80s.
Aug 03, 2012 | 1995 Cadillac DeVille
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Jul 19, 2011 | Isuzu i-Series Cars & Trucks
I am converting farmall h tractoer electrial system from 6 volt to 12 volt. Need a diagram of wiring using an alternator
If the kit contains a wire and a diode, one would ASSUME it is a standard "3-wire" alternator, rather than a less-desirable (goofy) "one-wire" unit.
Here's a simplified diagram.
Please note the diode, an "idiot light" or a 10 Ohm 10 Watt diode can be used interchangeably in the "excite" wire lead.
Jul 06, 2010 | Computers & Internet
Wiring diagram for ignition switch farmall 140 tractor
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
Sep 16, 2009 | Computers & Internet
How to wire up 1975 Ford Courier Alternator w/external regulator?
just put a one wire alt. on it.or test each wire.
Mar 26, 2009 | Ford Cars & Trucks
I have an 85 amc eagle, I cant get it to charge, it did not have an alternator when i bought it, i have a ford alternator on her now, but wont charge, does this car have the voltage regulator built in the...
you need to put a chevy alternator with a built in regulator on it.
You need a 3 wire alternator. Two wires go to the battery and one wire goes to anything connected to the ignition switch.
Nov 21, 2008 | 1984 AMC American Motors Eagle
Car Voltage Regulator Connection
Hi
The only thing that I need is the diagram on how to connect a voltage regulator (12 V), car unit
on my wind generator motor which my produce more than 12 V, according to the wind speed.
Sincerely
Nestor
Sep 24, 2008 | 1988 Daihatsu Charade
Farmall Cub Tractor Radiator Logo
1,260 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
john milligan
Are you a Farmall Garden Expert? Answer questions, earn points and help others
