Question about GN Netcom Jabra® SP500 Wireless Headset
Jabra sp500 I have a new phone and cannot connect it to the Jabra. I can get blue tooth connection but it asks for passcode of Jabra. How can I get passcode?
Use passcode as default one
example 0000 ( four zeros)
Posted on Mar 05, 2008
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
How do I connect my Jabra blue tooth to my droid
Turn off your Bluetooth device. After you are sure it’s off, hold the power button for around 30 seconds. Release the button and you should see the device start blinking. On your cell phone, enable the Bluetooth and in your options, search for a new device. The Jabra headset should appear in your device list now. Click on it and the two devices should auto pair without a passcode. If you are prompted for a passcode, try the default of 0000 or 1111
Aug 18, 2010 | Jabra BT4051 Bluetooth Headset
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Connecting to a jabra hands free
once you have found it it should then ask for a pin code which is either 1234 or 0000
once this is accepted then they should be paired completely
Nov 25, 2007 | Cell Phones
Jabra SP500 ssetup instructions
have the jabra sp500 charged up and turned on. hold down the button near where you plug in the charger until the phone on the big button becomes solid blue (no flashing), then have your bluetooth turned on ready and pair device thru phone, it should link with the phone and allow you to save the settings. The End
Jun 03, 2007 | Jabra SP500 Wireless Headset
GN Netcom Jabra® SP500 Wireless Headset Logo
192 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
techmncpa
Level 1 Expert
MrFixitSTTL
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
