Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green light blinks constantly. reset doesn't fix it.
Green light blinks. reset doesn't fix it. blinks constantly and tv won't turn on. it happened after a power outage. set plugged into surge protector.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This set has a lot of problems but I have news for you that I recently discovered from a authorized Mitsubishi repair center---
Mitsubishi has had so many problems with this set that now they sell a complete Chassis replacement for this set for about 200 dollars--You will have to go to a authorized center---no more trying to fix individual boards in this set...if you are in doubt--Google the model number and you will see all the problems this set has had---
Contact Mitsubishi and I think the best thing you can do is get the Chassis replaced--
If you have more questions about what I am telling you let me know---I think Mitsubishi is trying to avoid the class action lawsuits that are in progress against them for this model.
REGARDS, SD TECH
Posted on Oct 08, 2009
Testimonial: "Thanks for the tip. I left it blinking for 2 hours and tried reset again and it worked. But next time i'll use your tip to find the prob."
  • SD Tech
    SD Tech Oct 09, 2009
    NOT SURE HOW THIS HAPPENED BUT WRONG ANSWER PLACED HERE FOR BLINKING GREEN LIGHT:ONLY 1 or 2 things can cause this problem----First thing to do is
    remove front speaker grill--it should pull out and is secured with plastic
    pegs--behind it you will find an inspection plate---Notice the one or
    two pairs of wires coming from the front keyboard
    of the set---remove the inspection plate and follow the wires to the
    right--you can unplug both plugs(most have two and they are marked with
    letters and different sizes so you cannot get them wrong)
    The
    idea here is to remove the front keyboard with its reset button etc
    from the circuit---You will still be able to try to turn the set on
    with the remote---these sets have a Receiver(large metal box to the
    left as you look from the back) and if the power goes out the green
    light will blink for about 70 seconds and then go out---it is the
    Receiver booting up.
    If disconnecting the keyboard allows the
    set to turn on--you have a bad reset switch and two choices---either
    operate the set only with the remote or to remove the front screen and
    get at the reset switch (it is tiny) and remove and/or replace it.
    If
    disconnecting the keyboard does not restore the set to operation---the
    receiver is bad---there are 4 or more caps and some pico fuses that can
    fail in that unit---Mitsubishi no longer sells or repairs these--if it
    is bad and not the caps there is a company you can send the unit to and
    have it repaired--if you need to know their name let me know---you can
    call them and get a quote for repairing the receiver.
    SD TECH
I have the same issue on my 52525.
1) Tried the bulb replacement and that didn't work.
2) Looked for two (2) wiresat the control panel. There were approx 8. Disconnected the entire harness at the connector. Tried the remote, nothing.
Tried the Menu/Guide method, got nothing from that.
Green light just blinks away. Is this thing an over sized paperweight?
Posted on Dec 13, 2009
It blinks 4 times
Posted on Dec 12, 2009
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
Hi, I have i Sony wega tv when i turn it on green and red lights flashes and nothing happens please help
The red light is key to your issue---is it blinking in a sequence--constant blink or for example 3 blinks, pause and 3 blinks?
Mar 20, 2012 | Televison & Video
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
458 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
