What type of speakers and turntable work best or will work with a Bang & olufsen 2400 reciever and 6000 reciever. thanks
  • Anonymous Mar 17, 2014
    bang and olufsen turntable won't power on
    Scholar:
  • 148 Answers
I believe this Beomaster series needs amplified speakers that goes with it. You might use the RCA out and make it amplified with another receiver or amplifier and use ''usual'' passive speaker.
Posted on Oct 08, 2009
Testimonial: "thanks for your input I may put som active rl35's with it from B&O again thanks for taking the time. John"
How do I add new phone to Pyramid wall charger for 6000 B&O phone which does not have a light
Might be best to read this article which explains the differences and similarities.
PSTN Bases Phone Compatibility Explained
The appropriate user guide to suit your system will be available on this site. Choose the correct model.
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/phones/beocom-6000
Sep 13, 2014 | Bang Olufsen Lands Phones
Hi, I have a B&O beocenter 1800 with a really load hum on the right hand speaker. This occurs on both radio and turntable. I have swapped speakers and cables and hum stays with RHS speaker output
this old timer probably has an output amplifier fault.with a circuit diagram any competent engineer shoulb able to locate the problem with the turntable removed access is easy and so is replacing parts
Nov 19, 2013 | Bang and Olufsen Audio Players & Recorders
How do I change Bang & Olufsen Beosound 2000 door belt?
I just did that ; took an 031 oring or was it an 032; and you have to pull the whole drive mech out; it is tricky and if your not small mech inclined don\'t do it; There is a few gears and they work in tandem so when you put it back together it has to be just right; if you take it out take pictures of it as you take it apart because you will never remember how it goes back together; easy to get out; a pain to put back together. And it will all come apart just to put that oring in.
May 31, 2013 | Bang and Olufsen Beosound 2000 Shelf...
Beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
I have four Beolab 6000 speakers and a sub-woofer. How can I use these with a Sony or Panasonic TV system?
That would depend on the unspecified 'TV system' and its speaker requirements and controls. Most TV's don't support directly-attached speakers. Since these are self-amplified, half the battle is won.
Have you looked at any manuals?
Register and download the 6000 manual for free at retrevo.com
http://www.retrevo.com/support/Bang-%26-Olufsen-BeoLab-6000-Speakers-manual/id/23302ci863/t/2/
The Beloab 6000 speakers DO support connection to non-B-and-O products through the RCA Line In jacks but that presumes you have external volume control.
The unnamed subwoofer probably won't work with a TV. More details would be needed.
This speaker system would work with any 'standard' component-style system if you wanted to use them for the TV AND other sources.
May 06, 2011 | Bang and Olufsen Audio Players & Recorders
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Stylus cartridge for a B&O record deck
contact this company for help?
service<remove>@turntableneedles.com
Note; take out the <remove> bit from the link to email them?
Oct 15, 2009 | Audio Players & Recorders
Connecting a sonos 90 to BO 8000 active speakers
Does your sonus system has pre-out? you can directly connect one single rca cable to each output into the speakers. make sure, each speakers is set to left and right each channel. these switches can be found above the rca input of the beolab 8000 next to the power link input. You have to understand that by using powerlink source cable is ideal only for other bang&olufsen equipments......however, there are other options, if u don't have a pre-amp output of your amplifier, you can also modify the speaker out of the amp, thru a conversion cable available from bang & olufsen, with an rca cable left and right channel, without interfering with the powerlink.
Apr 03, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Bang & olufsen stereo unit 9300
You probably burned the speakers.If you have the multimeter check the spekers for the resistance.It has to be 4 or 8ohms otherwise they are burned.And you have to check voltage on the amp connectors for the spekers.if there is any DC voltage presens the amp is also burned
Feb 18, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
322 people viewed this question
 Grubhead
Grubhead
