Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Its a plug electric fireplace.sparked i unplug when plug back in big bang unplug again
  • 87 Answers
It sounds like you are plugging it in when the unit is in the on position or(under load) make sure all switches are turned off before plugging it in. that will be a good place to start,
Posted on Oct 08, 2009
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Tip
Portable Heat Flame Electric Fireplace
Electric fireplaces are becoming more and more popular with today's homeowner's. The main advantage of the electric fireplace is generally portability, convenience, low initial cost is important. They also are a good choice when the looks are not as important as function.
Some electric fireplaces have simulated flames that give the look of traditional fireplaces. Another great option to include is a built-in fan to help distribute the heat more effectively. With some of these high end units it can be very hard to tell the difference between an electric fireplace and a wood burning stove. Along with this option may come a heatless setting the will give the look of flames but produce no heat. The remote control has also found its way to the fireplace market. There are many units that can be remotely controlled.
Electric fireplaces are generally cheaper than gas fireplaces. A good unit can be bought for about $500 (there are cheaper models available, but they tend to have fewer options and the flames are not as real looking). These fireplace units are fairly easy to install compared to a gas fireplaces or wood-burning stoves (both of which usually need flues to vent). If you can plug in an electric cord then this type of fireplace may be for you. The electric units are perfect for apartment buildings and condominiums. These places are not suitable for the traditional wood fireplace.
Just like other types of portable electric heaters, electric fireplaces will radiate heat very quickly extreme care must be taken to not have any combustibles too close to them.
You will see how an electric fireplace can transform any setting for you. The newest modern, advanced electric units have far more aesthetically appealing views. They might include fiber optic displays, or randomized lights designed to make the look of dancing flames.
Now whether you're living in a condo or apartment and can't have a real fireplace, the electric fireplace can be a great way to get some of the warmth and ambiance. Also remember that these units are very portable, so you can take them with you when it's time to move. Even though I have never been a big fan of electric fireplaces, because of the expense of their operation, I can see why they would be very popular with many apartment or condos owners.
http://www.fixya.com/support/r3707111-flame_electric_fireplace_electric
on Dec 25, 2009 | Heating & Cooling
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
My fireplace keeps shutting itself off never done this before
Is this a gas fireplace or electric? If you would post the make and model that would be a big help. IF it is gas then it has a flame sensor in it and those get dirty.
Jan 06, 2015 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace
Do you have a model number of the fireplace?
Nov 30, 2014 | Heating & Cooling
Electric fireplace
Is it that soud stay for long time, let say 10 minutes?
It can be some piece of metal moving when fireplace heats up.
If this fireplace has fan installed, small lousy bit of metal can play.
Nov 13, 2013 | Heating & Cooling
Febo Electric Fireplace Insert Using remote It Will Not Auto Shutoff when room reaches temp. also If room is Cold & Temp is set higer it will not turn on. U have to manually shut it if or on. there is...
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Oct 24, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
My electric fire is just blowing cold air?
It sounds as if the heating element has burned out (which is very common with electric fireplaces) or it overheated and the overload switch turned the heater off. Since you didn't mention who the manufacturer of your fireplace is or the model number, it's hard to make any suggestion on how to solve the problem. Other than one: Turn the fireplace OFF, unplug it and wait 30 minutes to plug it back in and hopefully, it will reset itself.
Mar 02, 2011 | Heating & Cooling
Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Dec 24, 2008 | Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Leisure Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Steve
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
