Question about Kinyo NB-100 Computer Speakers
Kinyo t3100 bass speaker has a rattle when playing music
  • 496 Answers
Try turning the bass down and make sure that the rattle is inside the speaker check around it and see if its not something nearby the speaker it could be something came off inside.
Posted on Oct 08, 2009
Hello my problem is this I have a subwoofer t3100 and what happens is that one day anyone was at home and went to turn my subwoofer normally and only sounded the speakers but not the bass. revising one day...
some internal part damaged now allowing you to trigged the system or maybe a wire may have became loose thus not allowing it to power up just you need a mechanic or can open and check your device it is easy . if any part broken you can use fevi quick to join it to work again
Oct 05, 2013 | Creative Labs T3100 Computer Speakers
Dre beats left ear "rattling"
Right now I am having the same problem. When the bass goes high it's an awful noise like rattling and I'm afraid I blew the speakers. But I was only listening to them on a simple iPod 3rd gen. Please helpppp!!!!
May 29, 2012 | Monster Cable Products Monster Beats...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
I have lots of static in my Inspire t3100 speakers.
Speakers are't really capable of producing static but can REproduce static coming from the amplifier.
If speakers are defective they can rattle (loose cone) or can produce random scratchiness if the voice coil is going bad. This last can also happen if a speaker has a lousy connection from the amplifier.
But I'd guess that the amplifier is at fault.
Nov 29, 2009 | Video Game Consoles & Games
When i play certain bass, like mainly highs, but not all highs, my speaker seems to rattle. no im not an idiot. i know subwoofers rattle stuff when you have them on. i know almost all there is to know...
It is possible to overdrive a speaker beyond what it can handle.
DO NOT BELIEVE the spec sheets regarding power and capabilty, especially those for automobile amps and speakers.
If the cone moves too far, the voice coil leaves the active area of the magnetic field and the speaker will "rattle".
The speaker AND its enclosure may be resonating at particular frequencies.
If these things are happening, you will permanently damage the speakers.
Jul 29, 2009 | Rockford Fosgate P112-200 Car Subwoofer
SPEAKER'S RATTLING
check bass setting, too low or too high(frequency)
Sep 06, 2008 | Jensen XA2150 Car Audio Amplifier
1999 Toyota RAV4
Hey Robert. It could be one of a few things. I had trouble with my speakers too.
If you still have the factory head unit in your car, the static may be because the speakers are damaged.
If you have a new or non factory head unit in it and you have the factory speakers in the car, the speakers will have a static sound when turned up because they have trouble supporting the amount of watts and power that are being supplied to them.
Another problem I think of when you say static is the metal and plastic or your car "rattling" against each other when bass shakes the area around your speaker. If that's the case, you just nee to put something in there that surpresses the amount of vibration that comes off your speaker and flows into the speaker mount.
Hope this helped.
Jun 12, 2008 | 1999 Toyota RAV4
Kinyo NB-100 Computer Speakers Logo
62 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
