Question about Toshiba 32AF45 32" TV
Toshiba 32AF45 turning off by itself OFTEN.
My grandparents have a Toshiba Model 32AF45, and seem to have the same problem that a few of the other people are listing. The TV is just over 3 years old and keeps turning off ALL DAY long for no reason. It takes 2-4 times of turning the set on for it to finally stay on. What is the problem with this model that it does this and how can they fix the problem????
    Sergeant:
    Champion:
  • 269 Answers
Check the sleep timer mode
Posted on Oct 08, 2009
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
I have an older toshiba t.v. model 32AF45. the remote does not work and i cant get any other remotes to work on it either. the picture is kinda dark. is there a way to access the menu without it?
Hello
The remote sensor inside your TV is not working. It does not receiving infrared signal generated by your remote control. There are two main reasons for this problem. The first one is the defective infrarred sensor itself. The second one is, there is not sufficiant voltage to the remote sensor to work properly. The remote sensor can be located just behind the infrared sensor window at the front of the Tv. It will be diretly soldered to the front panel control printed circuit board. It is a thhree terminal component, look brownish black in colour, very cheap to buy, and can be bought from most of the electronic spare part shops at your town. It will look somewhat like this.10_23_2011_3_43_31_am.jpgThere will be typical number printed on its body, and it should be noted when buying a new one. You must ahve a concept of desoldering and soldering, some skill to repair elactronic ciruit boards to replace it by yourself.As far as your sectond complaint is cncerned, lack of brightness, may be of so many reasons. As you know, a TV is composed of hunderes or thousands of small components, and each of them have their own "duty" while the set works. If any one amouhg them have a fault, it will effect the whole working of a TV. Typically, a dark picture may be of ow screen voltage. Screen voltage can be adjusted, and there are adjustment points for screen and sub-brightness. But this is a very skilled work, and and unexpereienced one can't do, and is dangerous. OK.10_23_2011_3_44_44_am.jpg
Oct 22, 2011 | Toshiba 32AF45 32" TV
I need to know the remote pin code. I have an external converter box with a remote and need to know the number to program the new remote.....please help
Toshiba has 18 codes, they are 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141 0156. Gerald
Sep 09, 2011 | Toshiba 32AF45 32" TV
Tv goes off by itself every few minutes
You have bad solder grounds in your TV. There will also be some bad capacitors. Look for capacitors in the range of 160 volts to 250 volts at 1Mf to 2.2, 3.3, or 4.7Mfs that are bad now. Another common capacitor that goes down are the 25 volt or 35 volt 100Mf ones. The next area would be your vertical IC , it will need resoldered. This is true any most cases of any brand. The capacitors next to the vertical IC will need checked and replaced. A bad cap here will heat the vertical IC and separate the pins from the board. Last and be sure to do this. Check the small board connected to the picture tube. By now this board (CRT) will have many bad grounds. Heat is the enemy of any television. Hope I could clue you in to a repair. Thanks for asking and show a few hands of support!
Mar 20, 2011 | Toshiba 32AF45 32" TV
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
TV turn off by itself
The easiest way to describe this is to measure the center pin to either outer pin. If either combination reads shorted, that is the problem.
Dan
Sep 03, 2008 | Toshiba 32AF45 32" TV
Toshiba e310 turns on by itself
On your device, go to activsync tools/option and click the Schedule tab. Uncheck "When connected to my PC, synchronize with the server every:"
Uncheck " When not connected to my PC, synchronize with the server every:"
It turns itself on in an attempt to synchronize with a server.
Mar 16, 2008 | Toshiba e310 Pocket PC
Missing channels
Try going through the auto program feature first and see what happens. Otherwise if the set is new have it replaced.
Apr 12, 2007 | Toshiba 32AF45 32" TV
TV Problem After Lightning Strike
check the diodes or the regulator. the diode are most likly shorted that the 4 d's like d800, d801,d802,d803
Dec 26, 2006 | Toshiba 32AF45 32" TV
Toshiba 32AF45 32" TV Logo
507 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
