Question about Texas Instruments TI-30 XIIS Calculator
How do I add Exponents on my T1-30xa calculater
  • Texas Instru... Master
  • 7,993 Answers
There is a rule of Algebra, that says
(a^m)[x] (a^n) = a^(m+n)
a is the base of the power, n, and m are the exponents. As you can see, multiplying two powers of the same base is equal to the power of the (common) base with the sum of the exponents.
If that is what you had in mind, the calculator uses the rule correctly and no intervention from you is necessary.
If you enter (2^4)[x](2^6), the calculator will give 1024, which is 2^10.
I may be wrong, but what you call add exponents refers really to performing addition where addends (the terms you add) are arbitrary powers, such as
2^7 + (5.5^3) - (1/3)^4
Once you enter a power term, the calculator calculates it and the result is now just a number. It can be added, subtracted, multiplied
For the exemple above
2 [Y to the x] 7 + (5.5)[Y to the x] 3 -(1/3) [Y to the x] 4 [=] yields 294.3626543
For the cube of 5.5 you can use the key combination [2nd][X^3]
Hope it helps.
Posted on Oct 13, 2009
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
Jan 26, 2016 | Casio ClassPad 300 Calculator
What is factoring and give the examples
Quick-Start Guide When you enter an expression into the calculator, the calculator will simplify the expression by expanding multiplication and combining like terms. At this point the calculator will attempt to factor the expression by dividing a G C F, and identifying a difference between two squares, or factorable trinomials. Use the following rules to enter expressions into the calculator. Variables Any lowercase letter may be used as a variable. Exponents Exponents are supported on variables using the ^ (caret) symbol. For example, to express x 2, enter x ^ 2. Note: exponents must be positive integers, no negatives, decimals, or variables. Exponents may not currently be placed on numbers, brackets, or parentheses. Parentheses and Brackets Parentheses ( ) and brackets [ ] may be used to group terms as in a standard expression. Multiplication, Addition, and Subtraction For addition and subtraction, use the standard + and - symbols respectively. For multiplication, use the * symbol. A * symbol is optional when multiplying a number by a variable. For instance: 2 * x can also be entered as 2x. Similarly, 2 * ( x + 5 ) can also be entered as 2 ( x + 5 ) ; 2 x * ( 5 ) can be entered as 2 x ( 5 ). The * is also optional when multiplying parentheses, example: ( x + 1 ) ( x - 1 ). Order of Operations The calculator follows the standard order of operations taught by most algebra books - Parentheses, Exponents, Multiplication and Division, Addition and Subtraction. The only exception is that division is not currently supported; attempts to use the / symbol will result in an error. Division, Square Root, Radi cals, Fractions Division, square root, radi cals, and fractions are not supported at this time. A future release will add this functionality.
that's all I can say basically I learned it this way.
Jul 09, 2015 | Office Equipment & Supplies
Write with positive exponents
To rewrite an expression with positive exponents, you must use the identities
1/a^n=a^(-n) and 1/a^(-n)=a^n
Example: a^(-3)=1/(a^3)
1/(a^(-4))=a^(-(-4))=a^4
To convert a whole expression, you scan it for negative exponents and start changing them one a time, until you get only positive exponents.
Depending on the expresiion you are dealing with you may have to use other rules, such as (a^n)^m= a^(n*m)
Mar 30, 2012 | Office Equipment & Supplies
I have an Acer 5542 which has a "P" button in the top right hand corner. When I first purchased the comp. the "P" button bought up a window with about 4-5 options in it, and I chose the...
@eessom
I have this problem. The whole menu disappears. It seems to drop out of its own accord.
Three things that help 1. Enabling Launch Manager in Services 2. Search for Launch Manager > open > select and add apps using the ADD button (you can set it to Launch Manager so you always open the little console) 3. Put a shortcut to Launch Manager on Desktop and keep an eye on it.
Sam
Feb 06, 2011 | Acer Aspire 5542 Notebook
How would you do negative exponents for scientific notation? example: (6.0 x 10^6)(2.0 x 10^4), I am required to use the EE button for my exponents since it's a scientific notation equation but I do not...
Use the (-) key for negative numbers (not just exponents) instead of the - key. The - is to subtract one value from another, (-) is to input a negative value.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
Adding Exponents on a Casio fx-300MS
The calculator applies the rules during the internal calculations. But all it shows you is the (final) result. It does not keep track of what exponents you used to get to the result. It is not capable of doing symbolic manipulations.
Hope you are not too disappointed.
Apr 22, 2009 | Casio FX-300MS Calculator
I cant figure out how to put exponents in to my calculator
For 5 to the 6th power, type
5 ^ 6 =
You should get 15625
Mar 24, 2009 | Casio FX-300W Plus Calculator
Entering a problem
Hi Loringh,
see, high exponents are +ve powers, while low exponents are -ve powers.
e.g. for 1200000=1.2X10^6=1.2E+6 (high exponents)
for 0.0000000012=1.2X10^-9=1.2E-9 (low exponents)
I think so easy ?
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Dec 12, 2008 | SoftMath Algebrator - Algebra Homework...
Texas Instruments TI-30 XIIS Calculator Logo
478 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
