Question about HP Photosmart C6180 All-In-One InkJet Printer
Can't print on photo paper from iphoto
Not sure how to get printer to grab 4x6 photo paper from middle slot. it keeps trying to pull paper from bottom standard paper tray.
    President:
  • 1,564 Answers
When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
Posted on Oct 08, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How to set for 4x6 photos
Nothing special to set for 4x6, you lust slide the paper guide over to the 4x6 paper and stand the paper up in the paper slot in the back. You have to choose 4x6 print in your printing software window in printing preferences.
Jan 31, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Getting a borderless print
Try this if that helps:
Using iPhoto to create borderless prints To use iPhoto to create borderless prints, please follow all of the steps below:
  1. While logged in as an Administrator, install the latest Canon printer drivers onto your computer (with Mac OS X v10.2 or later as the operating system) and select the appropriate printer as the default.
  2. Launch iPhoto.
  3. From iPhoto, select and open the image you wish to print. (Please refer to the Apple web site for instructions on how to use iPhoto.)
  4. When you are ready to make a print, select from the Menu Bar 'File: Page Setup'.
  5. The Page Setup dialog will appear.
  6. Select the following settings:
    1. Settings: Page Attribute
    2. Format for: <Select the Canon printer you wish to use>
    3. Paper Size: 4x6 (borderless)
    4. Orientation: <Select the matching orientation>
    5. Scale: <Select the appropriate scale>
  7. Select 'OK' and the Page Setup dialog will close.
  8. From iPhoto, from within the Constrain section of the browser window, select from the pull-down menu (i.e., the button directly above the Constrain label) either '4x6' or '4x6 Portrait'. Then, using your mouse cursor, mouse-over the image and when the Cross-Hairs are over the upper left-hand corner of the portion of the image you wish to print, click and drag from the left to the right in a downwardly diagonal motion, releasing the click at the end of the image selection.
  9. Click the 'Crop' button.
  10. From the Menu Bar, select 'File: Print', select your options, then select 'Print'.
  11. This selection, revealed in the iPhoto window will now print as a borderless, 4x6 print.
I hope this information allows you to resolve this issue. If you need further assistance,
please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to
rate this post....thanks!
Apr 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
257 people viewed this question
Seeker5211
Seeker5211
