Question about Black & Decker 18", 6.5a Electric Mower
Replace blade on electric lawn mower - Black & Decker 18", 6.5a Electric Mower
  • 389 Answers
IF IT IS A CORDED MOWER MAKE SURE IT IS NOT PLUGGED IN -
IF IT IS CORDLESS, MAKE SURE SAFETY DEVICE (KEY) IS REMOVED
If you have a work bench, place your mower on the bench on its side or upside down where you can see what you are doing. If no bench, the floor of your garage or your driveway will work too.
Get a small 2 x4 block, a C-Clamp or some other device to keep the blade from spinning.
Get a ratchet or breaker bar and socket to fit the bolt in the center of the blade.
After you are sure the blade is blocked from spinning, turn the socket and ratchet to the RIGHT (clockwise) to loosen the nut until you can completely remove it.
When you install the new blade, look at it to see if it is marked "grass side" if it is not marked, the sharpened area on the blade should have the "beveled" edge toward the housing and remember the nut will turn to the left (counter-clockwise) to install and tighten. (Electric mowers have LEFT HAND THREADS due to the rotation direction of the motor.)
Posted on Oct 08, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
Too much noice & vibrations on my electric lawn mower of late
The blade is most likely unbalanced. Have you tried cleaning the blade? If caked on grass & dirt is not the problem, you should replace the blade.
May 25, 2010 | Black & Decker 19" Electric Lawnhog...
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
BLack and decker electric lawn mower blaDE IS loose and not turn
If it's like mine (MM 875), it has a plastic "clutch" that has little edges on it that broke off when I was chopping sticks with the mower ;-) Went to the local B&D place and got a new one for less than $3.
But now I'm worrying about the nut holding the blade on -- if I try to get it good and tight, the plastic "clutch" spins around off-kilter... Funny how I never even looked at the blade after I bought the mower used, but never worried about the blade being loose and flying off.
Mar 03, 2009 | Electric Lawn Mower
Black & Decker 18", 6.5a Electric Mower Logo
377 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
