Question about Dryers
Teflon shoes in front keep wearing out
My teflon wear pads in the front, there are two of them, keep wearing out. I have checked the two rollers in the back, they both appear to fine. Any ideas what would cause the teflon pads to wear out?
    Sergeant:
    Champion:
  • 205 Answers
Please use rubber pads better than teflon.
Posted on Oct 08, 2009
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
My Maytag elec. dryer squeaks bad. It sounds like metal on metal. I have changed the felt gaskets and the teflon wear pads and belt, what else could it be? Maybe the support rollers. Need help.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 17, 2011 | Maytag Dryers
Sceeching sounds
your drum glides the drum rides/.rests on in the front behind the cover are worn out,they are made of teflon and when this teflon layer wears thin then the drum rides on the teflon backing and squeals/screeches,replace them
Oct 29, 2010 | Amana NDG233AW Gas Dryer
When is on it makes a bird chirping noise that goes away after a while
Hello- Depending on the model you have it is most likely either the front or rear bearing. The front bearing on some GE's is actually a series of 3 teflon strips attached to a plastic support and the rear bearing is a ball and socket type. The teflon strips do wear down over time and then the drum starts to wear into the plastic support. The rear bearing "socket" also wears over time and can cause the drum to sit a few degrees lower in the back and cause squeaking. It may fade as the dryer heats-up because some metal parts are expanding and plastic parts wear in a certain grooves, so to speak, once they have been moving for awhile. Unfortunately you will probably need someone out to disassemble the dryer and find the specific cause. You may be ok to just live with it for awhile but it could be causing more damage to the parts as time goes on, meaning a higher repair cost. Hope this helps a little, best regards.
Sep 28, 2010 | GE Dryers
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
After making a lot of copies- Dialta 3010 copier jams every time
you probably need you fuser rebuilt. the heat roller melts the toner into the papew. it is covered in teflon. over time the teflon wears off anf toner sticks to it causing paper jams when the copier gets hot
Dec 30, 2009 | Konica Minolta DiALTA CF910 Copier
I have GE profile Model DPSR473EW with loud squeak when drum turns ? I also need to learn how to access the drum etc...
I have experienced two problems with "loud squeeks" with the DPSR473EW. First, if you take the top off (open door, remove two screws under top door lip releasing the top), then.., remove two small screws (inside up high - one on each side) holding the front panel/door assembly on. Pull the front panel/door assy away from the main unit - can't seperate due to some wires near the blower. On the door/front panel assy..., you will see four "teflon slides" that fit into a plastic semi-circular assy (the drum rides on those four teflon slides). Most of the time, this is where the squeeks come from - I've seen them worn thru..., and the drum riding on the plastic (just order the teflon slides - qty 4 - WE1M333). If the plastic piece that the slides fit into is worn, replace it - WE2M26 (top bearing). This should do it. If the slides look OK (so the squeek hasn't been fixed), the other place for a squeek is...., the back bearing. This bearing is basically a male rotating plastic sleeve running in a metal female hole. I have seen those wear thru the plastic bushing..., causing lots of noise. To inspect that bearing, you will need to a) remove the belt (plenty of instructions on the internet), then b)remove the drum..., then..., you can inspect that back bearing (two pieces - one piece on the back of the drum, the female piece mounted on the heater shroud.. If you need to replace that bearing, or one half of it - you can order pn WE25M40 - it will have both pieces. Good Luck
Nov 15, 2009 | GE Profile DPSR473EW Dryer
Teflon as gear material...?
Basically teflon is what is known as an ultra high wear molecular material, meaning it absorbs impact and is slightly spongy so when there is pressure it reverts back to it's normal shape and does not wear rapidly. Using teflon with steel, basically the steel absorbs into the metal teflon molecules over time that create a slippery surface for both preventing wear, slick50 oil additive is a good example.
Using a soft material with a hard material such as chain will result in the chain eventually wearing out. A good example is a rubber hose rubbing on a piece of steel, the hose is unaffected and the steel turns shiny and wears into a groove first.
Aug 29, 2009 | Tamarack ArtiScan 2400FS Film Scanner
The dryer makes a loud noise and also a rubber smell develops after a 1/2 hour of use
My dryer did the same thing. I had to replace the front support glide assembly and needed 4 teflon glides.
The front part of the dryer runs over this plastic piece seen here upside down.
this part is about $50 CAN there are 4 plastic or teflon glides that fit into this.
My dryer had worn through the teflon glides and start wearing away this piece.
My dryer is a GE front load dryer. And I did get a burning smell because the dryer was wearing away the plastic. After the teflon strips wore down.
Hope this helps
Jun 01, 2009 | Kenmore Dryers
Frigidaire dryer makes noise when it tumbles
"spindle" would seem to refer to the rear drum bearing but teflon would describe the front. Have they both been done? Usually when one is worn out the other isn't far behind. Check the idler arm/wheel for wear. Also motors make a sound when the bearings are bad
Jan 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
