Question about Freezers
Admiral F2076 I have an Admiral F2076 that's been sitting in my garage, unused. Is it frost-free? Is it worth donating or should I get rid of it?
    President:
  • 1,304 Answers
To be completely honest i would get rid of it
way to many headaches with this model
and the people you give it to wont like it
Posted on Oct 08, 2009
I have. Beko frost free freezer at the back of our garage. For some reason it is triggering the rcd. Any thoughts!
Check door seals for folds or dropping door sound like a air leak normaly you will see frost build up right were problem is
Jan 30, 2017 | Frost Freezers
Freezer in unheated/unairconditioned garage it stays cold in winter time but it is not freezing when the temperature is hot in the garage
The first thing is to find out if there is a fan that runs next to the compressor. If not then in the summer the machine is overheating and passing the heat up to the machine itself thawing or preventing the freezer from operation properly
May 17, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Can I put my Danby upright freezer in the garage? - it is not frost free.
It is always best to keep these types of equipment in the 60-80 degree ambient.
Sep 22, 2009 | Danby 16.7 cu. ft. / 473 liter Upright...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Proline freezer door leaking
If this is not a frost free model It sounds like you have a freon leak. This is almost never worth fixing. Any fix would be temporary. You can never really trust it again.
If it is a frost free model it could be just stuck in defrost. Most commonly the defrost timer.
Jun 30, 2008 | Freezers
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Jun 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Freezers Logo
82 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
