Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
I have a samsung LE32 73BDX TV. a grid of dots flickering infront
I have a samsung LE32 73BDX TV. When I turn it on it works except for a grid of dots flickering infront of the picture.
5 Suggested Answers
SOURCE: Samsung LE32R87B
I had this problem with my tv but i kept getting a black grid over anything red... i returned it to samsung and they replaced it
Posted on Sep 03, 2007
  • 210 Answers
SOURCE: samsung LE32 tv does not turn on. blue indicator
this is a common fault take back of and look on main power board for blown capacitor's ( raised tops ) they look like little batteries with white line down one side replace then with same value e.g ( 2000mf 25v)
remember what side line is on (TAKE PICTURE) for capacitors look on Charles hyde and son web site(CHS) under general components listed on left side of page
Posted on Dec 13, 2009
  • 586 Answers
SOURCE: i got a samsung le32
Connect your TV to a DVD player. If there is still no picture, it means the display inverter of your TV is defective.
The display inverter is what makes the TV brings picture. Since the TV is no longer bringing any picture, the display inverter is the first thing that needs to be checked as it is most likely the cause of the problem.
Please give me feedback if you need any assistance in locating or identifying the display inverter.
Your sincerely.
Elect_Comp.
Posted on May 16, 2011
gopakumarg43
  • 74377 Answers
SOURCE: Samsung LCD TV LA40S81.... Turn on
Hello
It is due to the power regulator section of your TV. If DC voltage come to T'con board and other circuit board won't have enogh regulated and smoothed current this type of fault will occur. Open your Tv and check for any bulged capacitors on the mains power regulator board. If there, repalce it with same type and capacity. I hereby attaches a picture, of an other set's power supply board with bulged capacitors to give you an idea about how a damaged and bulged capacitor will look like. Check this, If you want anymore assistance from me, feel free to get me by Fixya.
gopakumarg43_41.jpg Note the top of the red arrow marked capacitors. They are damaged. A ggod one will look like one you can see on the top right with flat top surface.
Posted on Sep 04, 2011
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
When scanning dots show up in a vertical pattern
Printer DPI and PPI Ratings, General Dots per inch stands for the maximum number of tiny spots of ink that the printer can place in a straight line where the spots are theoretically small enough (i.e. ignoring spreading or smearing effects of ink on paper) that if placed in every other such dot position leaving white space between them, the spots can be individually distinguished. Pixels per inch stands for the maximum number of unique positions in a straight line that the printer can place an ink spot under control from the outside world, namely from a computer connected to the printer. Lines per inch stands for how close thin parallel lines can be printed and still be distinguished in the finished printout. The spaces between the lines count as "lines". Pixels per inch and dots per inch originally referred to the same thing. The printer mechanism was under the direct control of the computer and was physically positioned and placed dots as directed by the computer. Back then, most printer mechanisms were limited to placing dots only in positions suggested by a grid of dots X per inch horizontally and Y per inch vertically, for example 100x100 dpi Nowadays, many printers put dots "wherever they want" as opposed to in positions suggestive of a horizontal/vertical grid. Still there is a minimum dot size and a minimum dot spacing. A picture file (image file) represents pixels in a uniform horizontal/vertical grid pattern. And the printer needs to make a finished picture of the size, say 5x7 inches, that the user chose regardless of the number of pixels in the picture file. To simplify the process of relating the pixel count in the picture file to the possibly non-uniformly spaced dots on the paper, the printer or its supporting software may generate a temporary intermediate picture file with a set number of pixels per inch. The printer may have, internally, several choices of ratio of pixels to dots and the published rating can be the largest ratio except that the published rating may not exceed the dpi rating. Therefore there might be three "per inch" values involved at a given time, the pixels of the original picture file, the pixels per inch that the printer works with, and the dots per inch of the printer mechanism. Pixels per inch is usually not mentioned with printers. All printers come with their own software (including parts called drivers) to install on your computer. Usually the software does not let you exercise control over individual dots using your picture file. Rather the printer takes your picture file or data file and uses its own built in logic to lay down the dots and create the printed output. We are led to believe that a printer's ppi is usually a fraction such as a half or a third of its dpi rating. When a temporary picture file is created, there are at least two levels of software in use. High level software (which may run in your computer) takes your picture file and creates the temporary file. Low level software runs in the printer, takes the temporary file and controls the dot size and dot placement on the paper. Sometimes a printer is advertised using a phrase such as "300 dpi 1200 dpi quality". This means that the printer has some way of making dark edges on a light background appear smoother than the first number would otherwise suggest. A printer with 300 dpi 1200 dpi quality definitely cannot resolve alternating dark and light pixels less than 1/300'th inch each. But curved and diagonal lines and color boundaries should not have jagged edges suggesting individual dots rigidly positioned on a grid with a 1/300'th inch pitch.
Oct 24, 2010 | HP LaserJet 3050 All-In-One Printer
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Unit intermittently makes the TV flicker the sound and picture.
I would be checking and trying new leads from the antenna part of your telly to where they go into the wall , we had a problem with a new tv that used to turn itself off and on we got the tv replaced with another new one and it still did it . it turned out to be a faulty cable from the pay tv box on top of the telly as they emit FM waves just like the radio and it was sending signals to the remote on the tv to turn it off
May 17, 2009 | Samsung HT-WX70 Theater System
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
Picture Would Come In and Out, Now Not at All
It seems as though from your description it is just the brightness changing. The Cathode Ray Tube has three electron guns at the back end. These are for green, blue, and red. Each gun has a cathode and a grid. Nearly all control the brightness by having the grids tied to a variable voltage. And nearly all control the colour and luminance by an amplifier connected to each cathode. As you do not say the colours change the the amlifiers are OK. I would suggest the voltage to the grids ( or cathodes in some), is unstable due to a bad connection or a dry joint, or a faulty resistor in that part of the circuit. Very old sets without remote control used a potentiometer to vary the brightness. A voltmeter is all that is needed. When the picture goes off try holding the increase brightness for some time, to see if it reappears.
Oct 28, 2006 | Panasonic CT-36D32 36" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
104 people viewed this question
Henry  Thomas
Henry Thomas
