Check your Qt filter. Set it to the off position (the minus symbol) on both radios. Once you have your Frequency, Interference Code Eliminator and Qt Filter set identical, the radios should communicate. If not, you have a radio with a problem. Or a bad battery. (Bad batteries can also cause some user problems, such as no transmit or intermittent transmit.)
WE were just testing the radios and one is receiving fine, the other when I try to send a message...
(More)
WE were just testing the radios and one is receiving fine, the other when I try to send a message just beeps? The batteries are fresh, I have a feeling I've accidently hit something on the menu...???
My T5500 Motorola does not start Scan - when I press the Mon button nothing happens - I have tried...
(More)
My T5500 Motorola does not start Scan - when I press the Mon button nothing happens - I have tried holding the button for 1 second and upto 1 minute also - no luck - somebody help!!
