Output board for Altec Lansing ADA995
My altec lansing speaker system.
the output for the satillites has no sound
need replacement for the board or replacement for the parts..
    Problem Solver:
  • 7 Answers
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Posted on Feb 26, 2008
Why does it emit a loud whistle when turned on?
I got rid of my Altec Lansing because I got white noise when the unit was turned OFF. They are not a good make. You can try moving any wires or magnetic influence away from them. I now own Bowers and Wilkins MM1 speakers which are amazing.
Bowers Wilkins MM 1
Mar 14, 2016 | Altec Lansing New Original Dell ADA995 5.1...
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Altec Lansing ADA995 Speakers. Can these speakers be used with a home audio system (Technics) or a television (Phillips). JRS Denmark jrschou@live.dk
Hi there , not long ago I was having issues with my VS 2420
I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following
Contact: nicky.cook@alteclansing.com , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Feb 24, 2011 | Altec Lansing ADA995 Speaker
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
Hooking 5.1 computer speakers to a Samsung Plasma
Computer speakers are powered, they have their own amps inside the speaker cabinet.
To get these to work on a TV you need to plug them into a headphone out jack.
The external speaker terminals produce too hot a signal for powered computer speakers. The amp in the speakers may have already been damaged.
May 04, 2009 | Altec Lansing ADA995 Speaker
Need a driver for the altec lansing 45.1
i'm guessing you have an audio output problem.
you might not have installed the sound card driver or your sound card is not functioning.
this speakers does not come with drivers... just plug in to speaker output which is the green one. turn the speaker on and walah!
Jul 31, 2008 | Altec Lansing ACS 45.1 Computer Speakers
775 people viewed this question
 Grubhead
Grubhead
