Question about Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop
Igniters will not work
My kenmore gas cooktop had water spill into two igniters. none of the igniters will work now. breakers have been checked and are not tripped. what would be the next logical step in getting the igniters repaired?
  • shaile3 Feb 28, 2008
    striker will not work have to light gas by match. kitchen aid cooktop
  • 33 Answers
Did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Posted on Jan 04, 2008
All six of the ignitors on my vgsu161bss cooktop are not firing--- electrical supply is working
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
Aug 16, 2011 | Viking 37 in. VGSU161 Gas Cooktop
Spill water on cook top by gas knobs. now the igniter is clicking on all the time with the knobs in the off position
Each of the knobs has a little white rotary switch on it's shaft below the cooktop. You've likely got water in one of those switches and it's making the connection in the switch to start the igniter circuit. Unplug/turn off the breaker to the unit. If it's just water and not a sauce or noodle water or something else impure, you may be able to let it dry out without too much trouble. You could try pulling off the knobs and sucking at the openings with a wet/dry vac to try to get more water out of the switches. The worry is corrosion from being wet too long. If it isn't working after drying out, you'll need a new set of switches. http://www.appliancepartspros.com/part_details.aspx?part_id=3185909
Mar 16, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Burners are sparking when none of the burners are turned on and only stop when electrical source is shut off.
Water has gotten into one of the igniter switches (below the burner knob). Disconnect power, let it dry out for several hours, and things should work again just fine.
Jan 02, 2011 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
None of the four burners will ignite when the gas is turned on. The electric igniters don't spark. The gas comes out and can be ignited with a separate butane lighter. I believe the electric power is on to...
Check that electric power closely. A boil over and attempted re-start or water (or other liquid) leaked / spilled into an igniter switch can trip your GFI outlet. Sometimes the outlet the cooktop is plugged into is fed from a GFI recepticle further " up stream " so you may have to look around to find a GFI which has tripped.
Feb 08, 2010 | Cooktops
THE IGNITERS WILL GO OFF WHILE THE BURNERS ARE ON COOKING. IS THIS SAFE AND HOW CAN IF FIX THIS PROBLEM? I HAVE KENMORE GAS COOKTOP MODEL# 91132229100
It is not dangerous, but very annoying. Most likely you need a new spark switch. Or simply unplug it for 24 hours and see if it dries out. Usually people spill stuff on them.
kenmore stove repair in orange county, ca
appliance repair orange county, ca
Feb 08, 2010 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
I spilled water on the cook top and one burner is constantly clicking
cut the power at the breaker, wait for it to dry completely then turn back on. clicking noise is probably electricity arching
Jun 13, 2009 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
Kitchenaid Gas Cooktop with electronic ignition
you sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
Nov 09, 2008 | KitchenAid Cooktops
Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop Logo
285 people viewed this question
Top Kenmore Cooktops Experts
Kolbrun...
john mabry
Jay Plesset
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
