Question about Honeywell Programmable Thermostat Heater
My thermostat reads 17.0 degrees and the word "filter" is flashing underneath. What does the word filter suggest?
    President:
  • 1,304 Answers
You air filter is dirty
its down inside the airhandler where ever that might be n you home
Posted on Oct 08, 2009
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
I HAVE A HONEYWELL T8600D 2028, CHRONOTHERM IV PLUS DELUXE PROGRAMMABLE THERMOSTAT, AND THE TIME/DATE SETTINGS DO NOT HOLD; EVERY MORING, IT FLASHES MONDAY, 1pm. ANY SUGGESTIONS? I RESET TIME/DAY,...
pknab, I have the same problem. And it comes down a few things: 1) the flashing 1:00 indicates that you've lost power, and the system needs to be reset. 2) Reset means taking out the batteries for longer than 5 minutes. 3) You have to change your filter monthly. There's one in the cold air return and another one in the furnace. If you don't, your FURNACE may be causing number one (my conjecture). 4) We had an electrical storm 2 days ago--nothing else in the house lost its sense of time...but...well...the online operating manual is difficult to find try http://customer.honeywell.com/techlit/pdf/69-0000s/69-1400.pdf or http://dl.owneriq.net/e/e67c2c91-73c2-4bd8-abc8-91d843a27658.pdf (but it doesn't tell us this stuff...I'm still looking for the meaning of the EEE in the display..perhaps I have repowered the thermostat/furnace in the wrong order).
Dec 07, 2010 | Honeywell Programmable Thermostat Heater
Skil 2100daf angle finder
I was trying to reset the zero on my angle finder. It's a Powerfist Digital Angle Finder, the same as the Skil 2100.
After turning the unit on, if I press the Miter and Hold button together and hold them, the unit goes into 'calibration' mode. (The display flashes 0.0). If you do nothing, it will always stay in this mode forever after that.
You can then reset your unit - it takes time however and patience.
With the aid of a large protractor, draw angles on a large sheet of paper (I used a couple of 11 X 17" pages) from 0 degrees all the way up to 220 degrees.
Turn on your angle finder and make sure the numbers are flashing 0.0. This will be your 0 degree reading. Hold the finder closed and press the Hold button once.
The display will now read 10 degrees. Open up the finder until it matches your 10 degree marks on your paper and press the Hold button again.
The display will now read 20 degrees. Open up the finder until it matches your 20 degree marks and press the Hold button again.
Continue setting your angles in this fashion up 'til you reach 220 degrees. The next button press will close the calibration cycle and the numbers will stop flashing.
Your unit is re-calibrated. Now, if it's off - you've only yourself to blame.
Apr 23, 2009 | Skil 2100DAF Digital Angle Finder
My central ac system occasionally runs too long and the temperature gets way too cold. The digital thermostat reads that the temperature is too high so the ac still runs. This doesn't happen all the time...
I have seen this is many digital thermostats. The worst problems usually come from the touchscreen thermostats. I would suggest installing a new thermostat. Make sure that you read the instructions before you even remove the old one.
Jul 03, 2008 | Heating & Cooling
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
158 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
