Question about Kenmore 57029 Side by Side Refrigerator
How do i replace the ice making dispenser( the whole thing wires and faceplate) on the front of my kenmore fridge
    President:
  • 1,304 Answers
You should see two tiny holes on each side of the facier of the dispensor
put a small nail in the whole and pull lightly
it should pop off giving you full access to all the components
Posted on Oct 08, 2009
I have a Kenmore side by side fridge with ice/ water dispenser in the front door. When I push the water dispenser the water comes out the spout but also some comes out behind the spout making a mess. Is...
sounds to me that the line inside of the door is cracked. Their is no easy way to repair that, either the entire door must be disassambled to replace that line,or replace the outerdoor panel with the line embedded into it,to replace the door panel it requires transfering all the compentents fmor old to new door panel, a partial list of things that must be transfered parts from old to new outer door include but not limited to
inner door panel
door gasket
dispenser asm (which cant come out as one piece and must to disassabbled into appx. 20 parts)
wiring
hinges
door handles
Jul 26, 2011 | Kenmore Side by Side Refrigerator
Remove Faceplate on fridge
I am have the very same problem. I removed the dish beneath the water/ice dispenser, and located two small screws. These two screws appear to hold the bottom of the face plate to the door. I removed them. However, the faceplate still did not come loose. I suspect there are more screws or clips toward the top.
Nov 20, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Ice maker not getting water
Hi, The first thing to check is the inlet tube going through the back wall. Make sure it isn't plugged with ice. If the inlet is open, you can remove the front cover on the ice maker and locate the to holes marked M an N. Use an insulated wire and strip off about 1" on the ends. Insert the wire ends into these hole and see if the white gear on the ice maker head starts to turn. Let it advance through the cycle and see if you can hear the inlet valve hum when calling fpr water. If water enters the icemaker, you will need to replace the head modual board or the whole ice maker. There is not much difference in cast.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Kenmore 53642 / 53644 Side by Side...
How do you turn off the water dispenser in 59562990?
If it has water and ice, the inlet valve will have at least 2 coils. You can pull the fridge out, take off the bottom panel and pull the 2 wire connector off just the water coil. Depending on the fridge, there may be multiple choices, look for the tube that does not run up the back of the fridge and disconnect the wires going to it. Then try the water dispenser, if you don't have water you should be ok, if you still do, replace the wires you've taken off and try another connector.
Jul 22, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer makes ice but has trouble dispensing it
are you still making ice in the icemaker?? if so then you most likely have a bad water inlet valve (back of unit right side behind the panel) The crappy thing is the icemaker and the water are on what is called a dual valve you have to replace the whole thing.. to test this you will need to sw the wires if you want to get into this let me know
Jan 17, 2008 | GE GSS25JEMWW Side by Side
Ice maker/water dispenser
Jan 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Dispenser motor/Dispenser light
I assume that the problem is that the ice dispenser is not working. If you have put 120v onto the auger motor and it won't go, then obviously the motor is faulty. Reconnect the motor to the wiring harness and put your tester on the white & blue wires. Push the door switch so the fridge thinks that the door is closed and push the ice dispensing lever. If you get 120V to the motor and it won't go, replace the auger motor.
Nov 01, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
117 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
