Question about Dell Dimension 4600 PC Desktop
When I turn my computer on, the monitor shows the Dell logo and then goes into sleep mode. I cannot change any settings or adjust anything since the monitor goes blank almost immediately.
    Guru:
  • 126 Answers
Try to change your Graphic Card inside, and have some test if these monitor stays sleep mode.
Posted on Oct 08, 2009
  • 3 Answers
I had this problem when i bought new monitor..... restart your computer in safe mode... i think its press f8 on bootup, i will double check for ya... this allows you to change monitor settings without monitor going to sleep on you....once you choose safe mode and windows has started... right click on desktop, then goto properties, click on screensaver tab... click on monitor power (lower left) look for power schemes then change turn off monitor to NEVER. click apply, then ok. close everything and then re-start normal...
this worked for me when i replaced my monitor with an lcd.. it also worked when i broke my laptop screen and had to use a seperate screen...
one thing is you monitor taking power supply from the wall or your tower?
hope i helped ya :)
  • iTzNoTaNRR Oct 08, 2009
    hi, just double checked it is f8 on bootup to goto safe mode :)
Erm i got this problem in the past. What i did was contact the dell people and they change the motherboard for free.
2 Suggested Answers
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
Dell ST22200L monitor goes into sleep time mode
Its in your power settings. Access it same as when you set the screensaver, is one way. Other times go straight to power settings.
Apr 19, 2017 | Gigabyte GA-F2A88X-D3H Motherboard
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Dell Monitor changes colors, red, green, blue
Contact Dell service center for changing settings in monitor, on site. Not a big problem.
May 23, 2010 | Dell E176FP 17" LCD Monitor
Why does my monitor say "no signal" when you try to us my computer after it has been on sleep mode?
The computer turns off the signal to the monitor after it goes into sleep mode. You can adjust the power settings in the computer to not turn off the monitor.
Sep 21, 2009 | Acer X193W LCD Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Feb 22, 2008 | Dell Dimension 4600 PC Desktop
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4600 PC Desktop Logo
481 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
