Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Air compressor needs a new hose from engine to tank
Campbell hausfeld iron force air compressor bought used with no connection from outlet on engine to the inlet on tank. i've looked everywhere for a parts list, but i dont know the exact name of the part. where could i find a replacement hose for the compressor?
  • steelcaps98 Oct 08, 2009
    tried that, but i dont know technical name for part or part number
  • mickey813
    mickey813 May 11, 2010
    IF YOU SEND ME THE MODEI # ILL FIND THEM
    Sergeant:
    Champion:
  • 269 Answers
Go to the manufacturer's website and order it
Posted on Oct 08, 2009
Compressor will build up air pressure to shut off point then will release air pressure for about 30psi
Check Valve in the tank where the air
enters from the tubing leaving the compressor
Call Campbell & get a new one
They are good to talk to on the phone
& you can order parts without all the internet hassle
Sep 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Compressor is getting so hot it is smoking
Make sure you are running compressor oil in it. Not motor oil.
Apr 23, 2009 | Campbell Hausfeld 26 - Gallon Air...
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Tank pressure reaches setting but outlet pressure is not releasing air
if you have a air nozzle I would plug that in and see if you can get air out of that if no then you may have to adjust the hose/line pressure or you may have something inside that isn't allowing the air to come out of the tank in that case drain the tank and use either a small rod or peice of wire to poke through the outlet and clear it
Sep 26, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
194 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
