Question about Necchi Sewing Machines
My machine is Model #981668. My whole bobbin case
My machine is Model #981668. My whole bobbin case fell out I forget how to put it back in. Could you please send me a
picture out of the book as to how it goes?
I put my book somewher and can't find it.
thank you
My husband put it together. It's been a while since I used it.
Thank you anyway.
Posted on Oct 08, 2009
The bobbin thread won't catch on the needle thread. The whole bobbin case fell apart and I'm not sure I put it back correctly.
to check the asembly
do a needle /hook timing check
with the needle fully down the hook of the bobbin carrier should be almost at the needle
as the needle starts to come up the hook should be just at the needle eye or slightly above it but not over it
Dec 13, 2017 | Sewing Machines
The needle fell in the slot, my husband turned the machine upside down and the needle didn't fall out but a piece of the bobbin area fell out and I don't know how to put it back. Any suggestions.
Without knowing the make & model machine, we are basically unable to assist. Probably, the best thing you can do is download a copy of the user instructions:
Make Model manual
There should be an access cover to the bobbin area. Most likely, the needle is either stuck inside the bobbin area or has dropped through to the bottom of the machine. As for installing the bobbin & bobbin case, the manual should have instructions for your to follow.
May 22, 2017 | Sewing Machines
Need help reassembling bobbin area.
You didn't state what model you have, and that makes it tougher to help you.
I'm going to take a guess here that the part that fell out is a silver U shaped part located on the right near the bottom of the bobbin basket (holds the case). If that's the case, it's called a "cushion spring" and can just be reinserted by hand. It is part of the assembly that prevents the case from moving while the thread is unspooling from the bobbin during operation.
Oct 30, 2014 | Singer Sewing Machines
Bobbin housing has come out, I cannot get it back together
Hi This machine uses the standard class 15 bobbin. It sits inside a bobbin case that has a finger that needs to be located in a retaining slot. It the whole lot, bobbin, case, hook assembly and retainer have come out simply turn the machine over so that these parts can be fitted downwards. fit the hook, then the retainer and lock it into position. Put bobbin into case pull thread under spring. Lift tab on case and put it over the hook's central pin and release tab. It should now be locked in position
Feb 17, 2014 | Singer 2250 Tradition
The bobbin case on my 2273 (the whole thing) fell out and I need a diagram on how to put it back.
If this is the Singer 2273, then did the hook cover and hook come out? See the pictures on page 2 of the oiling diagram here: http://www.singerco.com/uploads/download/1235_oiling-2263.pdf .
If you need to replace these two parts, turn the handwheel until the hook race is in the left position. Then put in the hook (thickest part down) and then the hook cover (the side with the notch towards the machine and facing up). Rotate the hook retaining arms back towards the center of the hook cover to lock it in place. Now you should be able to put the bobbin case back in. Since this is a part that needs to be oiled regularly, wipe it out with a soft cloth and put 1-2 drops of sewing machine oil at point 6 (just to the right of center) in the shuttle before you replace the hook.
If additional parts have come out or the retaining arms are damaged, try finding the parts diagram for your model at the Singer site: http://www.singerco.com/support/replacement-parts-chart . THen see if a Singer dealer has replacements available.
I hope this helps.
Nov 18, 2011 | Sewing Machines
Thread is getting stuck around bobbin case in lower part of machine after 3 stiches. I have take the whole assembly apart several times and put it back together with no luck solving the problem.
Try turning your bobbin around, it may be facing the wrong way and it will get caught around the bobbin casing. I had that problem until I turned it around, just the bobbin in the case not the case.
Feb 18, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Jun 20, 2008 | Sewing Machines
Sewing Machines Logo
100 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
