Question about Panasonic Lumix DMC-TZ3 Digital Camera
Will not power up
Will not operate properly. Camera froze. I removed battery & reinserted - no luck.
it has done this a few times before but eventually worked.
i measured voltage on battery -- from + to -, 4v, from + to T - 2v
    President:
  • 1,564 Answers
Clean your battery compartment contacts with a cotton swab "dampened" with rubbing alcohol. Also clean the battery and the charger in the same fashion.
Posted on Oct 08, 2009
Frozen camera
And after removing the battery, you first charged the battery before reinserting it?
Because when a camera suddenly stops, most of the time the battery is empty. At least it does not have enough power to work safely.
Try charging the battery, and reinsert it. Then I hope everything will look different.
Still it could be the battery is not in working order, but you should notice a different behaviour when charging it. If it almost takes as long as normal to charge the battery it should be ok.
Feb 09, 2014 | Nikon Coolpix S3300
Multi color circle lines on images
I suggest that you perform a manual power resetting and check the operation.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Feb 11, 2012 | Nikon COOLPIX S70 Digital Camera
Lens doesnt close when switching of the camera bought it today!!!!!!
If lens won't go back, Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
--- Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
If this will not solve the problem your device need service (repair)
Good Luck & have a nice day
Rating the solution in highly appreciated.
Aug 18, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a camera it's a canon S5 IS i let a friend borrow it he dropped it and now the lens won't go back in it says lens error restart camera i need help
Lens error occurred due to external shock, Now lens is prevented from properly extending or retracting.
1) Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
or..
2) Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
  • Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
Rating the solution in highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot S5 IS Digital Camera
Flash witeout
Hi there, you mentioned continuous shooting right. Your mean Sequence mode? One click and 7- 12 continue image sequence wise? If its then the problem is, your camera battery is not good now. He is not able to give required power supply to you camera flash. When few snaps done after the he loss his battery power & flash power going under(-) & your camera motor going slow, that's why shutter not open and close proper time. And the final result is whiter & whiter images. Hope you understand, what i am saying. So change the battery & buy a new original battery.
Thanks & waiting for your feedback.
Feb 15, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
When I turn on my camera it says Access and after a few seconds it says turn on and off. When I do that it does the same thing over again
Hi there, Please confirm before power on the camera that, your battery is fully charged. If yes then remove the memory card & turn on the camera. Hope that time your camera working properly. Some time virus infected memory card not allowed to turning on the camera.
But with out memory card if the same problem happens then reset your camera or visit Sony service center. Because your camera operating system is corrupted and need to reinstall it again.
Thanks & waiting for your further quarry or feedback.
Feb 13, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Hp photosmart R927. No power, no operation, no LCD, battery good.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 28, 2009 | HP Photosmart R927 Digital Camera
Lens won't move stuck halfway out
looks like the lens assembly servo mechanism is malfunctioning.
try to push the lens in manually-push down gently until in and power the camera after.If that does not help you will probably need to change the lens assembly (it should be done by a proffessional)
Apr 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
145 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
