Question about Dryers
My Admiral dryer does not heat up but everything else does work. It is gas. What do I start looking at? The lint trap is clean by the way.
    President:
  • 1,304 Answers
Look at your ignitor
if it doesnt glow white hot it is bad
Posted on Oct 08, 2009
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
No heat
Gas or Electric? For both you want to check the ventilation system first, make sure everything is clear.. and your lint trap is clean. If it's gas it most likely its the coils going out on the gas valves and the gas valves should be replaced.. If it's electric bad heating coil/thermostat/control unit.
Nov 16, 2011 | Dryers
Dryer heats short time when first started then no heat rest of cycle
Well if it's a gas dryer and if your dryer tumbles, but there is no heat or less heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information and please don't forget to give some information about the brand and model number.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Dryers
My roper dryer is not giving off any heat. and everything else works just fine. The dryer is only 6 years old. I also just cleaned out the lint trap straight through.
You did not say if your dryer is gas or electric. So if your dryer is electric go check out this electric no heat tip...
and if you dryer is gas check out this gas no heat tip....
heatman101
Aug 27, 2010 | Roper Dryers
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
heatman101
Mar 30, 2010 | Roper Dryers
Gas dryer quit heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Gas dryernot heating up
hi,
try and reset the motherboard by unplugging power and waiting a few minutes and plug back in. What did you clean your dryer with?
If it was sharp you may have nicked a sensor, buy the wiring diagram and study away. Use caution with gas of course, shut it off look for shutoff , the flexible lines are brittle, be careful take time.
J
Jun 29, 2008 | Whirlpool LER5636P Electric Dryer
Admiral Dryer turn on and heats up but will not automaticly stop after its cycle
Did you have any lint build-up in the vent exhaust ? I need to know before we proceed.
Jan 16, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
239 people viewed this question
Top Dryers Experts
