Question about Apple Audio Players & Recorders
How to ko some one with one punch
I cant get hit in my jaw because is broken
  • 496 Answers
Ummmm hit em on the head really hard?
Posted on Oct 08, 2009
Replace guide bearings on jwbs-18 saw
" That one will be a press fit onto that eccentric shaft. Small bearings like that are easy to drive off with a suitable punch or mandrel. Simply stand it up in the jaws of a vise so the jaw edges contact the outer rim of the bearing and use a hammer to drive it out. Put a washer or similar bit of metal between the shaft end and the punch to protect the face."
Make sure before you put the new bearing on that the shaft is clean and smooth.
Nov 07, 2013 | Jet Machinery Jet Equipment 708750B...
Dewalt DW972 frozen chuck
Spray with WD-40 and let sit for a while and try again. If it is still stuck, tap on the end of the jaws with a nail punch to loosen them up and add some more WD-40. Try opening or closing the jaws and repeat. Usually it is due to some rust on the jaws and it may take several attempts to loosen it.
Sep 22, 2013 | Dewalt DW972 Battery 1500mAh, 12V, Ni-Cd
Can a dentist treat a broken jaw?
There are some less severe cases of broken jaws that most dentists can treat although in most cases you will need to visit the emergency room of your nearby hospital.
Feb 03, 2013 | Health & Beauty
Cant remove broken impeller
Lift off. You may have to attempt to pry it off with two screwdrivers. Other method is to hold it by the impeller while someone takes a brass punch and a hammer and gently hit the end of the shaft to knock it free. Try to avoid damaging the shaft or you will have to dress the shaft up to get the new impeller on.
Aug 20, 2012 | Beckett Waterfall Pump W5000 4983 gph
Front door latch jams and door wont shut
It sounds like the jaws are close. you need to pull on the door latch lever and hold it open use something round like a punch. not your finger. and open the jaws. if the door latch is not bad your door should close and latch normal.
Feb 25, 2010 | 2004 Chevrolet Aveo
I cant get the drill to open up to remove the bit. What do i do?
Your chuck is jammed. You can use a punch that is the same size as the jaws and a small hammer. You can tap the jaws back with the punch ever so slightly. Tap on each jaw the same amount of times. Start on one jaw with one tap, then to the next, and then to the third. After tapping each try to turn the chuck to open. This will dislodge the jaws slighlty and you should be able to move it. Keep doing this until you can open the chuck or remove the bit. After removing the bit spray some lubricant into the chuck and work it back and forth the whole length of the jaws. If this does not work you can put the bit in a vise and use a rubber or soft end hammer to hit the chuck off the bit. In this case you will have to replace the chuck. There is probably a bad spot in the jaws that is stripped.
Oct 08, 2009 | Drills
Drive bit won't come off drill
You can use a punch and hammer to tap the jaws back in slightly and turn the chuck as you do this to each jaw. This will at least let you get your bit out. You need to hit it hard enough to move it but not too hard as to damage it. Finesse it. After removing the bit try working the chuck jaws in and out all the way. If you feel resistance you may want to get a new chuck.
Sep 12, 2009 | Dewalt 18 Volt Compact Drill Kit
Cv joint
is it on the driver side or the passenger side? when i have a little trouble i use a slide hammer. put the nut on the shaft and use the 3 jaw attachment of a slide hammer this will help you.
Sep 01, 2008 | 1997 Toyota Camry
23 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
