Question about Whirlpool Dryers
Where is the fuse located in the model wed5830sw electric dyer
    Sergeant:
    Champion:
  • 269 Answers
Dryers usually use the house fuse
Posted on Oct 07, 2009
Where is the thermistor located on model # 110.67032601
I couldn't find it either on the Sears diagram even with a search. What makes you think it is the thermistor? If you have a no heat problem it is probably not. If the dyer runs but not heat first keep it simple make sure there is 240 VAC at the outlet. If you have one bad fuse or a bad circuit breaker it can cause a no heat situation. There are many components that can cause a no heat situation if that is what you have. I need more information to help you.
Aug 06, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
My dyer will not turn on this happened before an i had someone com out and they replaced the fuse. i neeed to know where it is located and where acn i buy the fuse at.
It will be the fuse agin most likely.
All lint and obstructions must be cleaned from the dryer exhaust system and the attached vent hose.
Need a model number for the fuse location.
Mar 04, 2009 | Frigidaire Dryers
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore Model 97310100
Are the coils getting voltage do you know? Or you can check the thermal fuse to see if its open.
Oct 23, 2008 | Kenmore 62602 Electric Dryer
Where is the fuse?
The fuse is located in the dryer fan/blower wheel cover and is a one time fuse, which means it is not resettable. I did a look up for the kenmore model # that you gave and I cannot find your model listed. If you go to parts.com and do a search for your dryer you will be able to see all the drawings on your dryer. You will be able to find the replacement part # and how to get to it. Test your fuse to check if it is open if it is, then replace the fuse. There is also a temperature sensor on the back wall of the dyer drum (it is a small metal circle close to the exhaust outlet). Sometimes there is simply a build up of fabric softener residue on them that stops the dryer from heating up. Clean the sensor with an alcohol wipe.
Hope this helps and don't forget to get all the lint out of the dryer before putting it back in service.
Jan 27, 2008 | Kenmore 64942 Electric Dryer
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
