Question about Motorola Mobility H500 Wireless Headset
LG 8350 Discovery
I have followed the instructions to hold down the button on the Motorola and then ask the LG to discover, however, it does not recognize it. Other thoughts?
Thank you so much,
0 characters
1 Points
Need to reset plantronics voyager pro heatset it pair with wrong phone and i cannot reset it or know how
to reset or pair your bluetooth device you need to put the device into discovery mode.To do this most manufactures use the power button,by holding the power button down for 8 to 10 seconds while turning the device on it should put it into discovery mode.Usually a light will remain on then you can find or search from your phone for new device.Once your phone has discovered the device it will ask for a pin\pairing code .Once again most manufactures use a 4 digit pin\pairing code they are as follows,0000,1234,9999, or 1111,try them in this order one will work. Hope this helps
Mar 22, 2011 | Plantronics Discovery 925 Bluetooth...
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
Configuring motorola bluetooth with blackberry
Following the steps how pair your head set with blackberry
1.With the headset off, hold the Multifunction Button until the LED remains on (about 2 seconds).
2 Perform a device discovery from the phone.
3 When the scan is complete, the phone displays the devices found.
4.Select the Motorola HS805 from the discovered devices list and confirm following the on screen prompts.
When prompted by the phone, enter the passkey 0000 and confirm to pair the headset with the phone.
Thank You
Sep 03, 2010 | Motorola Mobility HS805 Consumer Headset
Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
Plantronics Discovery Pairing Instructions
Good luck from Headsets Direct!
Apr 27, 2010 | Plantronics Explorer 330 Headset
How do i enable my wep 250 with a motorola v950
You will have ro place the headset in discovery mode this is usually done by holding the button down for about 5 to 8 seconds you will see the Bluetooth indicator turn solid blue or flash quickly.
Then you will need to go to the bluetooth setup on you phone once it discovers the device it will ask you for the pairing code which is usually 0000. Once it is done you should be on your way.
Good luck
Oct 17, 2009 | Samsung WEP250 AWEP250JBECXAR WEP 250...
My h710 will not go into pairing mode. I have tried holding down both volume buttons and call button but never goes into pairing mode. have not used this headset for over year
Make sure your phone is in discover as well. Also make sure your holding down all 3 buttons at the same time for at least 10 sec. then it should go into will blink then go solid.
Aug 17, 2009 | Motorola Mobility H710 Bluetooth Headset
Will a Motorola H710 Universal Bluetooth Headset work with a LG Scoop/UX-260? For now my answer seems to be no. :(
as long as your LG has bluetooth the anser is yes. Hold all three buttons down for 10 sec. It will go blue. you can now pair the devices. Just make sure to check the setting in the phone and make sure the bluetooth is set to discovery.
Jul 15, 2009 | Motorola Mobility H710 Bluetooth Headset
Motorola bt hs820 will not connect to my samsung a777, it just keeps searching for it. I asked before I purchased this phone if it would work and I was told twice by 2 different people it would work.
Hold the phone button on the headset until the light comes on and the head set beeps. When this happens start the discovery process on your cell phone. When the device is discovered it will ask you for the pass code to pair the headset. I can't remember if it is 99999 or 00000 check with motorola or the paperwork that came with the headset.
Jun 29, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility H500 Wireless Headset Logo
49 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
