Question about Pool & Spa
Pool cover pump quit working without warning. was not in deep water. pump is clean, no cracks or compromised wire. air vent hole not plugged. tried in a couple different outlets (power source) then put in the slop sink with a couple inches of water for a couple hours. just not working and don't know why? second season with pump and never left on cover to freeze during previous winter season. Any suggestions ?
  • 366 Answers
Take the cover off of the automatic shut off and check for debris. Most cover pumps have an auto shutoff and most of them have the type of valve that can be inoperable due to debris getting into the valve.
Posted on Oct 22, 2009
How do i check the pump
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Feb 25, 2015 | Reddy Heating & Cooling
How do I winterize my 2003 Winnebago Minnie?
You need to blow the all ware lines clean with a air gun nozzle. Empty/ drain all water storage units and pour windshield washer fluid or pool safe antifreeze in toilets and let stand. I would remove all batteries and stored with a 2Amp trickle charger until spring
Jan 02, 2015 | Cars & Trucks
Why is the pump pulling water but blowing air as well as water in the pool?
look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
May 08, 2014 | Pentair "Pentair" In Ground Pool Pump ...
Little giant pool pump cover will not work
auto switch is defective? a simple easy replacement can be sourced from any pool supply co
Jan 18, 2014 | Little Giant Pool Cover Pump Water Wizard...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Just had pool opened. They turned port dial to 2
Welcome to FixYa
Dear Sir/Madom,
If your skimmer is tied to your main drain, then both holes have to be uncovered for your skimmer to work.
If you have a separate line all the way back to your equipment from your main drain, then you may want to try to open both holes in the skimmers. Turn off your Unit to unscrew the retaining screw on the valve, and then slide the big end over.
If you've not had your pool run all winter, then you may have leaves/debris caught in the line.
If so-you can swing by a plumbing supply house and get a powerflush hose attachment.
  • Make sure that none of the holes in any of your skimmers are covered by the oval tab in the skimmer.
  • Then, if you have any valves on the inlet to pool pump, rotate them in such a manner to isolate the skimmer line that isn't working, making sure that it is open.
  • Place the hose and powerflush device in the upper inlet port of the pool pump, with the pump lid/cover and basket removed. Then, pressurize the line back to the pool with tap water.
  • If it doesn't release right away, then let it sit a little while, as you may have to "pulse" it as water pressure drops as water leaks around the clog.
  • Pulsing it means to turn the water on for a few minutes, then turn it off. Then, turn it back on, and then turn it off again.
Look down into the bottom of the skimmer. It will have either one or two holes, depending on your model. These holes are where the pool plumbing attaches to the skimmer. Most skimmers have threads inside the holes, and a copper or PVC threaded fitting screws into these ports. Squirt food coloring just above the holes and see if any of it is pulled down into them. This indicates a leak which may be caused by a poor seal between the skimmer threads and the fitting. If you put your finger into the holes, you should be able to feel where the top of the fitting meets the skimmer threads.Repair any cracks or breaks in the skimmer walls with epoxy putty.Use the silicone sealer to repair areas where the skimmer has pulled away from the pool wall, where the corners are cracked, and in tile cracks. These leaks are the result of a cracked bond beam or shifting soil from water getting into the ground around the skimmer.
Also Check this Link
I hope you got an idea...thank for Using FixYa...
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Kreepy cleans the deep end great. It cleans the walls and bottom but will not venture up the slant to the shallow end
There are several things that could cause these automatic pool cleaners to have this problem. First, check the return line water flor and redirect it if necessary. Also, make sure that the hose is long enough to cover the entire pool without difficulty. Also, check the hose balance to make sure that it is correct.
Jun 22, 2010 | Universal Kreepy Krauly In-Ground Pool...
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
88 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
