How do you troubleshoot a 1995 chevy a/c blower switch? blower is not getting power.
    President:
  • 1,304 Answers
Should be a single pole
ohm it out
put your leads on the paddles and turn the switch
it should read infinity open
and beep on closed
Posted on Oct 07, 2009
Blower relay in a 1995 chevy
Look under the dash behind the glove compartment to the left. To do so you will need to remove the glove compartment to see them on the top of the heater housing.
Jan 08, 2014 | 1995-1997 Chevy 1500 Truck Ignition...
How to take out blower motor on 1995 Chevy 1500 silverado 4x4
Sounds like two problems. No high speed could be the blower relay located by the blower motor. The blower motor is located under the dash on the passenger side of truck. You may need to take off the sound kick panel to see the motor. It is connected with 4 screws to the housing. Take out the screws and it should come out.
Jan 19, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
I replaced the blower on a 1995 chevy 1500 and it was working and now it doesnt! Do i need to check the relay switch?
Check the blower resistor.
I don't know the location ---you can
google that or go the You Tube
Nov 20, 2012 | Cars & Trucks
How to test blower motor switch 1995 mustang
check the connections at the rear of the control panel . check for power at resistor there is a blower relay
Jun 30, 2012 | 1995 Ford Mustang
Can you please tell me where the A/C blower resistor is located on a 1995 1500 Chevy Tahoe?
Thanks for stopping by:
Right inline on the power line at the motor. Up under the dash.
I'll see if i can get you a diagram....
Aug 04, 2011 | 1995 Chevrolet K1500
Just need to find where the blower motor resistor on a 1996 chevy tahoe
disconnect the negative side of the battery, open the passenger side door and remove the two screws
under the glove compartment box. remove the black cover from the resistor pack, remove the blower
motor resistor and replace it with a new one. re-install the cover and the two bolts, re-connect your
negative on the battery and your done. good luck!
Dec 10, 2010 | 1995-1997 Chevy Tahoe Ignition Starter...
Blower motor problems
yes the connecters on the blower are defects. after so many years they fall and not able to make proper contact. you most likely have to get the upgraded blower
Jan 06, 2010 | 1995 Chevrolet Suburban
Blower motor or resistor?
I had a truck about the same year with the same problem, it was the wiring harness, but id check the resistor and the fan first before replacing anythings,
May 20, 2009 | 2002 Chevrolet Silverado 1500
Blower control switch
do have any power on either wire going to the blower. the power runs from the fuse block through a relay, to the blower, to the resistor block and finally to the dash control. of you have power only on one side of the blower replace the blower. if you have no power at the blower replace the relay.
Hope this helps.
Mike
Jan 07, 2009 | 1995 Chevrolet Caprice Classic
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
