Question about Poulan Pro 22" Self Propelled High Wheel Mower
Won,t start, gas spark plug checkout - Poulan Pro 22" Self Propelled High Wheel Mower
    Problem Solver:
  • 18 Answers
Pull the bottom bolt out of the carb and then the the bowl. inspect for debris or water then clean out the bowl then blow out the little hole in the bolt. it probably has some **** in it. I see it all the time.
Posted on Oct 08, 2009
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
2006 kawasaki 250 ninja has spark, gas to the carb bowls but won't start
If plugs are dry then blocked idle jets are the most likely problem...
Sep 22, 2012 | kawasaki Ninja 250 R Motorcycles
2003 kia Sedona won't. start
If this is a sudden occurrence and nothing suspicious happened prior, you most likely lost either gas or spark to the engine. You need to check for both.
Do you hear the fuel pump in the gas tank buzz on for a couple of seconds when you turn the ignition key to ON? Unless the fuel pump turns on and puts gas under high pressure at the fuel injectors, the engine cylinders won't get gas to start. Correct fuel pressure is crucial to know if you have a fuel pump (or fuel filter) problem. If the pressure is correct, it is probably not a fuel problem but a spark problem, although there are less common instances where a fuel injector circuit may malfunction.
The ignition system not producing spark at the spark plugs is the other common problem of no starts. Buy a cheap spark tester at a parts store, plug it into one of your spark plug wires, then crank the engine over and watch for a strong blue spark. You might need a helper to do this. If you see a consistent spark, the ignition system is probably good, although you should probably check more than just one plug wire-sometimes one bad ignition coil in a coil pack will cause no starting. Good luck.
Jan 28, 2012 | 2003 Kia Sedona
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
