Question about Dryers
10 - 12 year old electric dryer. Doesn't turn on. Wires appear to be in good shape (yes it is plugged in and we checked circuit breaker) - unsure where to find product number
    President:
  • 1,304 Answers
The model number is on the door or inside the door jam
more than likely its a bad door switch
you can try jumping it out
Posted on Oct 07, 2009
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
Lead display is keep on flashing up on start sequence
Have you tried checking the fuse or the circuit breaker? Are both the washer and dryersharing the same two outlet duplex outlet or are they on two totally separate outlets? Just to eliminate/isolate the outlet question after you check the circuit breakers or fuses in your fuse box, try plugging the dryer into a separate outlet. If like many people you do not have an extra outlet in your laundry area, try plugging another item into the dryer outlet to check it for power. This is if you are talking about a gas dryer that works on a 120-volt electrical outlet. If it is an electric dryer it will be on a 230-240 volt outlet with a special plug. If you have an old circuit panel that is still using fuses as opposed to modern circuit breakers and if this Is an electric dryer, you would have a 240 volt disconnect plug more than likely inside the panel and if you firmly grab the handle and yank it straight out, you will see that the disconnect plug will have two short cigar shaped Buss Fuses in it. If this is the case one or more of those fuses could be blown. Depending on the electrical requirements of the dryer those two fuses amy need to be between 20-30Amp rated. or else if you have the manual take a look in it , perhaps one of the fuses is gone .
Apr 30, 2011 | Washing Machines
My Amana dryer won't turn on. It's plugged in but
First, check the circuit breaker at the circuit box and make sure the dryer breaker isn't tripped. If you have a voltage tester or access to one and know how to use it, unplug the dryer and test the voltage at the wall plug-in, This will tell you if you have good power to the dryer and indeed if the problem is with the dryer itself. These steps are usually overlooked by most homeowners and can save you a service call.
Good luck!!
Apr 04, 2010 | Amana NED7200TW Electric Dryer
Kenmore 62064 elec. drying is runing (all buttons
Hi Sam,
Make sure that you have checked the circuit breaker, to find out wither or not the breaker was tripped or not, before you take it apart. but there is a good chance that you are right on the money......
Dec 12, 2009 | Kenmore 62062 Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Could it be the heating element/coils?
From the info you've given, I'd suggest confirming whether the electrical circuit breaker arrangement for the dryer is single-pole (one wire and handle, 120V) or two-pole (2 wires and handles, 240V).  The heating element requires 240V.  Also, you mentioned a "fuse box". Hopefully you meant circuit breaker panel.  The wiring in any house old enough to have fuses instead of breakers would be a major concern unless you're into indoor barbeques in the middle of the night.
Jan 31, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
