Question about Goodman GMS90703BXA Heater
Ventor motor not coming on.
GMPN068-3 , S#9986626997, installed 2000. Getting 3 blinks, pressure switch. Checked hose for blockage, cracks- fine. Checked vent for blockage-fine. Ventor not coming on, all rollouits and limits OK. Ventor motor works fine when plugged in. Replaced pressure switch, still nothing, 3 flashes still on. Is board screwed ?
  • bndit1200 Oct 08, 2009
    Removed hose, blew out and visually inspected. Ran fish down exhaust vent, no blockage. Cut abs on vertical run, checked for blockage. OK. reconnected. Still has flashing light and no ventor motor working. Jumped thermostat wires, still nothing. Heat cycle not starting.
  • 10,515 Answers
If you have replaced the fuse and you can turn the fan on and off from the thermostat then the transformer is fine. If your a/c works then your transformer is fine. The error code could be a small blockage in the port to the pressure switch and not the switch its self. If you take the hose off form the furnace and poke a small wire in to that port and you should feel it break through then put the hose back on and try turning the furnace on again.
If the inducer never come on. It is most likely that the circuit board is not sending the signal to the inducer. Being that it is a Goodman furnace depending on the age of it it may be better to replace it then to fix it you may need the heat exchanger inspected. You can tell if it is the board if you have a volt meter and disconnect the leads on the board to the inducer if you have 120 volts its not the board if you don't have voltage it is the board.
If the humidifier is still connected take it off, the wires that is. Then the inducer is the motor that has the vent screwed down to it. Then follow the wires back to the board and take those two wires off and measure the voltage at the board. Make sure to have the furnace unplugged whenever you are taking the wires on and off. If you have 115v there the board should be ok, but my feeling about it is that the board and humidifier has been blown. But because the signal light is still coming on you have not have blown the transformer.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied with my solution!!
Posted on Oct 08, 2009
  • 15,935 Answers
Yes - 3 blinks is an error with the pressure switch.
You say you "checked the hose - but did you blow it out?
If the hose is clear, and you have replaced the pressure switch - the board has failed and needs to be replaced.
Thanks for using FixYa!!
Posted on Oct 07, 2009
4 red blinks, open limit switch. Replaced limit switch, still getting red blinks.
your ventor motor has to come on first to close limit switch,follow tubing from switch to ventor motor see iffu have 120 volts going to it, if 120 volts replace ventor motor assembley, no reset on board, board will reset every time u turn of power and back on
Dec 30, 2015 | Heating & Cooling
York Diamond 80, controller is blinking Code 3 (Pressure switch stuck open).
sounds like u nee a new pressure switch. check 1\4 inch tubing going to pressure switch, remove it make sure no condesation in it., blower will only come on once flame is establised, ventor motor comes on closes pressure switch, brings on ignitor then gas the blower, make sure no blockage in vent pipe
Dec 28, 2015 | Heating & Cooling
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Heat....Furnace will not start up worked fine last year it is getting power... I can hear I light hum in the furnace but it will not start it process
If its a high or mid efficiency furnace most of the time the sequence of operation goes as follows: tstat calls for heat (R&W at tstat ) ventor motor starts, pressure switch closes, spark or hsi lights pilot or main burners. main blower motor comes on. From your description of a humming noise it sounds like maybe the ventor motor is seized.
Oct 08, 2012 | Heating & Cooling
I have a Heil H9MPDO75F2AZ QUIET COMFORT FURNACE and have replaced pressure switch and still not running
Hi Kim,
A couple things to check:
1) OK, you've replaced the pressure switch - good stuff. But the neoprene hose running from the pressure switch to the inducer motor... does it have any tears or cracks? Is the hose fittings clogged on the inducer side? Clean/replace as necessary if so. You cannot have any leaks or restrictions in this hose.
2) Try disconnecting the inducer (spent fumes exhaust fan) motor and check this motor coil for continuity with a multimeter. If the motor coil is dead, you'll need to replace the inducer (about $120.00?).
3) Check during initial startup of a heating cycle that there actually is 120vac arriving at the inducer motor coming in from the control board. If not, your board may be at fault.
Hope this helps!
Papa Fixit
Oct 25, 2011 | Goodman GMS90703BXA Heater
I have a coleman unit the heater quit working. There is a red light that blinks three times. It represents ignition lockout. How do I fix it
Pressure switch error code, check air filter, condenstate drain and hoses, check for vent blockage, check for low spots in the venting holding water.
Dec 25, 2009 | Coleman Propane Forced Air Heater...
Have a dayton gas furnace #3E463A spoke to hiltonjug last week. purchased new air sensing switch and new gas valve. just installed new air switch and green light is not coming on on control box????
Is the pressure switch tubing installed correctly???...no holes in it???....and the furnace ventor motor is running????turn off the power and wait a couple seconds...turn the power back on with a call for heat and observe...the ventor(exhaust fan) should start running/....the pressure it causes closes the pressure switch and should power the 24v circuit to the circuit board turning the green light on....if not....check your vent outside....it could be plugged...this will also not allow the switch to close ....clean the vent etc....if the vent is clear and ventor running....ensure that the pressurw switch is actually closed...voltage test....and if it is then that wasn't your problem....need more info really
Oct 31, 2009 | Dayton Gas Furnace Heater
Goodman furnace no gas , 3 blinking
3 blinks is a pressure switch error clear the hose going to the inducer housing you may need a paper clip to stick into the barb fitting on the motor housing
Oct 02, 2009 | Goodman GMS90703BXA Heater
Heater wont start
does inducer motor come on?motor will be right below flue pipe inlet.if so make sure pressure switch closes.pressure switch tube could be kinked.also make sure furnace has good ground.sometimes not being grounded will cause this
Dec 31, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
291 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
