Question about Garden
Victa 2 stroke starts OK then stops
Victa starts then stops
After much mucking about, discovered that the washer on the fuel cap is missing. When the fuel cap is tightened it seals the fuel tank. Eventually the motor is starved.
It then starts and runs for progressively shorter periods.
Posted on Oct 08, 2009
What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Sep 03, 2016 | Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
Victa.two.stroke.wont.start
www.victa.com/au/support-centre/owner-guides
check spark.
If ok. chec for fuel inside on plug. If ok
check compression of engine.
Oct 12, 2014 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
How do you do the timing on a victa lawnkeeper? I know it is 3 deg but there is no marks so how do I tell where the 3 deg is?
The curent victa 2-stroke engine(power torque) does not have adjustable timing. All you do is set the air gap between the coil & flywheel and its set. The simplicity of modern electronics has done with points etc
The previous Victa 2 stroke engines sometimes had points which is located under the flywheel - on these you need to first set the points gap. Now the actual timing is 1/8 inch BTDC. The coil & points are on an adjustable frame ( plate or whatever you call it) which is secured by 2 bolts ( 7/16" headsize size from memory) - loosen these 2 bolts and you should be able to rotate the assembly about 1/2 ".as it has elongated boltholes. Rotate the motor (clockwise looking down) so the piston is 1/8" BTDC if its correctly timed the points should just be opening. Move the coil/points assembly ( & tigten the 2 bolts each time) till you get it right, In practice the timing does not need to checked - if it ran OK before then if you need to disassemble ,mark the coil/points plate & engine body so you dont change the timing
Dec 12, 2009 | Garden
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Garden Logo
1,653 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
