The picture on my new Visio 47'' lcd is shaking, like vibrating you can see it at the top especially, we have new HD cable box, using new hdmi cable conectors??
Vizio also hinted that its 120-Hz technology may reduce a video artifact known as "judder," a slight shaking of the video picture that is caused by the transfer process of 24fps material (used by many films and digital cinema) for display on an HDTV with a 60-Hz refresh rate.
Posted on Sep 28, 2010
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
Apr 19, 2010 | Kenwood VR-606 Receiver
SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Jan 15, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Westinghouse 47"lcd tv
are you using an hdmi cable or the red blue and green cables that came with the xbox? if using the original cables there is a switch on them that sets it to HD or standard. hope that helps
Jun 06, 2008 | Westinghouse TX-47F430S 47 in. LCD TV
Televison & Video Logo
341 people viewed this question
Top Televison & Video Experts
Electro Med Services...
