Question about Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230
How do you remove the impeller from a Waterway Executive 48 spa pump
Take off the back of the motor, put a wrench on the shaft and turn the impeller by hand to loosen. It may be reverse threaded.
Posted on Oct 26, 2009
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
We have an older version waterway executive 48 pump with top outlet 75mm thread and front outlet 90mm thread we live in australia and need to replace it can you give me some help on wher we can purchase...
It sound like that's the 2.5" x 2" wet end.
Spa Parts Shop can help you, they also ship internationally.
You didn't mention a Horse Power. The motors HP is likely wrong listed so provide them with the amperage of your motor as well.
Oct 26, 2012 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
How do i replace the slinger on my waterway executive 56 pump?
impeller screw backwards thread then impeller screws off regular just replace whole pump
Jul 02, 2012 | Waterway Executive Spa Pump 4hp Impeller...
Looking for the propella that goes in side.
Your old impeller should have a number on one side that starts with 3. It will read something like 3##-####. You can google that number for a number of online sources or if you would like a quote please email me using the contact feature found on our website at www.arrowpools.net.
John
Dec 31, 2010 | Waterway Executive 48 Spa Pump 15hp 1spd...
How do i remove pump from motor to repair or replace
Thank you for posting your question here on Fixya.com.
Remove the front cover on the pump and the shaft cover on the opposite end (back of the motor). Once the covers are off you can lock the motor shaft at one end using a screwdriver or wrench and then turn off the impeller counter-clockwise. Once the impeller is off you can remove the rest of the pump by loosening the 4 thru-bolts in the motor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Nov 28, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Hi , my executive 48 pump is leaking water at the shaft ...... is this some sort of bearing or seal problem ? thanks in advance for any help , andy dic
The pump seal is the problem and it can lead to bearing damage if not caught soon enough. The seal used in the waterway pump is not as easy as most seals to replace. You are better off to have it done at a pump repair shop or pool store than to tackle it yourself unless you are familiar with this seal and have the tools to fix it. A repair bill would likely be under $75 for a seal replacement at a shop and they can replace the bearings if necessary.
John
Oct 07, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Propeller is stuck, how do I free it up?
remove pump and wet end from spa
remove outer cover of wet end (small screws)
the impeller will be exposed.
remove any obstructions and then free it up by turning it
if it wont turn motor may be seized
replace cover, etc.
Sep 12, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Can<t remove impeller for my waterway 56 pump
This can be very tricky at times. Quite often a sharp blow from a hammer on the wrench will work. Sometimes an impact wrench will work too. If that fails, then remove the fan cover from and try holding the motor shaft with channel locks, or vice grips. If it has a fan, you might have to remove it.
Jul 02, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Execetive 56 4hp pump
Looking at the face of the pump, the impeller unscrews by turning it counterclockwise. Also, for some strange reason, the 4HP pump gets a 3HP impeller; the rating is embossed, in very small letters, near the center of the impeller. The 3HP impeller part number is: 310-4200.
Be sure to change the seal: US Seal P/n: PS-1000.
Oct 20, 2008 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230 Logo
1,546 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
