Question about Earthquake Sound DBX12 Car Speaker
Need manual or specs for earthquake dbx12 subwoofer
  • 84 Answers
There is four diff. modals db-12 street 1000watts max 4ohm.
dbxi-12 1500 watts max 4ohm
dbxi-12 1500 watts max 4ohm single voice coil.
dbx-12os 3000 watts max 2ohm.
hope thats what u need if u need more help feel free to email me bertman285@hotmail.com
Posted on Oct 14, 2009
2 Earthquake balls 12 subs specs for a vented box
Go to crutch fields website for sub box sizes and wiring it depends if you want vented ported enclosed sub box for your sub as to box sizes.
Oct 12, 2014 | Car Audio & Video
How do I set up a RX-V667 receiver to a Earthquake powered subwoofer? Will I need a special kind of cable?
The cable required depends upon the type of connector at each end. You could have an RCA connector on the rear of the receiver and terminals on the sub or maybe an RCA connector
Apr 13, 2013 | Earthquake MiniMe P8 8" Side-Firing...
What gauge wiring is best for an Earthquake Sound Magma 15X subwoofer?
at least 14 ga for speakers 8 ga for amp...be SURE to use an inline fuse between battery and amp
Sep 05, 2012 | Earthquake Sound Magma 15 Car Speaker
How much
how much is what?
Nov 08, 2010 | Earthquake Sound DBX12 Car Speaker
I have 15" subzero earthquake and i need to reconed
Usually the voice coil is bad on these subs...if your surround is rotted or torn - EXTENDING YOUR FINGERS PUSH DOWN GENTLY ON THE MIDDLE OF THE SUB AND RELEASE...Is it free? If not, forget the rebuild...If you need a kit for rebuilding the Earthquake...try Googling "Lesco Distibuting" in Orange City, FL and ask them who their closest Earthquake dealer is.
Good Luck
Jun 15, 2009 | Orion 15" Competition Subwoofer H2 15D4...
Dont know what i need to install this stuff
Hello bighollywood,
To install the head unit without cutting or tapping into the vehicle wiring, you'll need a "wiring harness". The Metra 70-1782 here seems to be the one for your '96 Prizm.
For the sub(s), you'll need an amp and a wiring kit. My recommendation would be the Alpine MRP-M1000. It's currently on sale at Crutchfield for $347. Shipping is included and you'll also get an "installation guide" to help with the wiring. The M1000 requires 4gauge power and ground.
Hope this helps.
May 17, 2009 | Earthquake Sound TREMOR XR12 Car Subwoofer
Earthquake eq-12 subwoofer parameters
I can't seem to locate the specs in my files or on line. From what I remember, you can use/build a sealed enclosure for each sub ranging from 1.5 to 2.5 cu.ft per sub. The larger boxes will play lower bass than the smaller ones at the expense of overall power handling and some efficiency. Ported boxes get a little more difficult but with some trial and error, they can be very effective. Even more so when tuned by the listeners own ear. Let me know if you need specifics on how to do this. Also General specs of your sub can be determined by knowledgeable audiophiles with a brief inspection. Perhaps a local electronics shop (if available) could help in this regard. Good luck and let me know if I can help further.
-Dynami
Dec 29, 2008 | Earthquake Sound EQ-SWS12 Subwoofer
My Earthquake Supernova MK-IV 12 stopped working
kindly check out maybe the fuse was already explode...check the connections specially the coil of the speaker using a multi tester....thanksss and gud luck
Nov 28, 2008 | Earthquake Sound MKIV-12 Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Earthquake Sound DBX12 Car Speaker Logo
515 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
xxxxxx xxx
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
