Question about Dryers
I HAVE A 14YR OLD JENN AIR DRYER AND NEED TO REPLACE ROLLERS, HOW DO YOU REMOVE THE DRUM SO I CAN GET TO THEN, HELP!!!
    Sergeant:
    Champion:
  • 205 Answers
First you should remove the gasket which is in front.
then you should remove the shock observers which will be fixed under the drum.
then you should remove the supporting clamps
then remove the pulley
then you can remove the bearing.
Posted on Oct 08, 2009
My whirlpool ler5620kq1 elec dryer is almost 8 yrs old and I am looking to replace belt and need instructions
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Aug 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer 6 months old. When in the drying cycle, a
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 23, 2010 | Samsung DV218AEW Electric Dryer
My six-year-old dryer was really quiet and is now extremely loud.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Now is a good time to check the belt condition for wear.
Good Luck,
I hope this helps
Thank You
May 17, 2010 | Asko T731 Electric Dryer
Dryer squeeks when tumbling what is wrong roper dryer 4 yrs old
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps
Nov 18, 2009 | Roper Dryers
Two year old kenmore dryer has loose drum
Your problem sounds like drum rollers that are worn very badly.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers to see if they are worn or the bearing area is worn or flat spots, if they are worn in the bearing area or have flat spots on them replace them.
Good Luck,
I hope this helps
Oct 29, 2009 | Kenmore 62602 Electric Dryer
My dryer is making a horrible squealing noise when there is a medium sized or larger load in it. it still dries and tumbles but i think a belt or something may be going bad. it is about 4 years old. can...
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 23, 2009 | Maytag Dryers
Started dryer as soon as the drum started to turn it started banging. the drum is spinning but there is no hot air going into the drum. the heating element does seem to be putting off heat.
#1 Problem: Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
#2 Problem: Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
Good Luck,
I hope this helps
Oct 22, 2009 | Maytag Dryers
Dryer is 11 years old. Hard starting( moans and struggles), and if I spin the drum it will start. the drum turns ok, it may be a little harder to spin than normal but not sure.
I think you need to check your belt and drum rollers.
Remove the front of the dryer. This will expose the drum and belt. Check the condition of the belt and replace it if it is worn or cracked, it may have slipped off of the idler pulley causing drag on the belt.
Remove the drum and belt and this will expose the drum rollers. Your drum rollers may be dragging or in need of lubrication.
If they don't have flat spots on them, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. I will include these two websites for parts and further help:
Good Luck,
I hope this helps
Oct 20, 2009 | Kenmore Dryers
My lg dle3733w dryer is vibrating a lot
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Good Luck,
I hope this helps
Oct 19, 2009 | LG DLE3733 Electric Dryer
My Maytag dryer is 14 years old. Now it makes a
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Yes, replacing the drum rollers is fairly cheap especially if you do it yourself, saves you the price of a new dryer for a few more years maybe.
Good Luck,
I hope this helps
Oct 08, 2009 | Maytag Dryers
Dryers Logo
Top Dryers Experts
