Question about Garden
Wont start unless I spray starting fluid in it
  • 718 Answers
There is a problem in your carb, stop spraying the starter fluid! Have it looked at or do it yourself.
Posted on Oct 09, 2009
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Wont start unless sprayed with starting fluid
I am going to assume ( dangerous) that you have a diesel. If the grid heater is working it is not advisable to use starting fluid because it can combust in the intake manifold. However, if the intake heater was working, you will not have any starting problems above 0F. I would check your grid heater for power and continuity. There could be a fuel delivery issue,but starting fluid usually does not fix that.
Feb 14, 2014 | 2006 Dodge Ram 2500
My ford econoline e150 wont start unless i spray starting fluid in it then it runs really bad then it stalls
Beings it starts with starting fluid, your ignition system must be okay. I'm guessing a bad fuel pump.. or possibly clogged fuel line or filter. I'd place my bet on the fuel pump being the problem.
Dec 06, 2013 | Water Heaters
Wont start
The injectors can't be spraying good or it would start. What is the fuel pressure reading?
Jun 14, 2013 | Cars & Trucks
1992 gmc jimmy wont start unless i spray with starting fluid after it starts it will start every time untill the next day then i have to spray again ?
Fuel pump issue.--
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 13, 2012 | 1992 GMC Jimmy
I have a 1996 camaro 3800 v6 and it wont start unless i spray starting fluid in it
If you continue yousing starting fluid your moter will become adicted to it in the long run it will hafto be rebuilt.fuel air spark need to be checked could be your choke system.
Aug 21, 2011 | 1996 Chevrolet Camaro
My Brand New Chinese 150cc scooter does not run unless you spray starter fluid in the carb and then it dies after 15 sec. Thank for your help. T.J.
buddy dont use starter fluid or your engine wont start with out it try spraying fuel on the inlet and see if it runs then get back to me if it trys to run
Oct 08, 2009 | 2008 Keeway Matrix 150
Wont start unless primed with starting fluid
Sounds like no gas reaching the motor. Could be fuel filter or fuel pump. I would recommed you disconnect the fuel line and start car to see if fuel is coming up if it is then ur injectors r clogged or no good if nothing comes up u know is pump or filter I would change both.
Jun 06, 2009 | 1998 Ford Windstar
Wont start without starting fluid
Could it be a plug up injector , have sewiing needle , stick it in the sprayer part of the injector on the carberator part
Aug 22, 2008 | 1990 Ford F150
Garden Logo
236 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
