Question about HP DeskJet 722c InkJet Printer
Paper is not feeding properly. Only feeds on second try with a push with my fingernail. Has been getting worse over time. 722c.
    Scholar:
  • 40 Answers
The feed rollers are dirty. There are professional cleaners you can buy specifically designed to clean printer rollers but if you were to use a paper towel with a drop of soap and water it would clean off all the paper dust that has accumulated on the rollers. Use a second paper towel with just water to remove any residual soap.
Posted on Oct 08, 2009
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper feed problem- am i best off replacing
If it was feeding paper askew, I would have thought the paper track may be partially blocked. A bit of paper of debris of some sort blocking a smooth run of the paper.
Having had a real good look, see if it can find anything, the next thing I try is passing a sheet of heavy gauge paper or card maybe, to see if that clears the track. Most printers have a paper feed function which bypasses printing a document.
Mar 23, 2010 | Canon PIXMA iP90 Mobile Printer
Paper not feeding thru properly
please the dumping roll and paper feeding pad is very celing and
who do use paper ? this paper is very glose papre ? if yes,
when one by one give up and second time
the paper is regulary use the friently paper and out of air in paper
and put the paper trey and use regulary ok.
Sep 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Riso tr1510
Take one of those flat plastic rulers and push it through all over.. so that any forein ripped paper whatever, clears the way.. The paper is supposed to buckle on entry.. That's how it's designed. It could be a timing issue.. when the paper is fed in it buckles against the timing roller.. the roller turns only when its supposed to. Each sheet stays buckled against the timing roller until it turns, that's how the machine draws only one piece at a time. It's could be the feed clutch.. There's a little magnetic clutch that actuates the feed roller to pull the paper in. when this feed clutch gets weak it barely works or it slips and doesn't pull the paper in at the right time. I've replaced these often on my equipment.. but I've also found that static electricity plays a big role. If your area is too dry, the paper sticks together increasing the resistance, pulling either multiple pages or just too much resistance for the feed rollers.. screwing up the time.. Make all adjustments to the feed rollers first to ensure it's not a huge problem before you start looking for a clutch. Essentially if the paper doesnt make it into the feed roller on time it is a timing issue.. but it's starting from the feed rollers.
Feb 03, 2009 | Sweet Beginnings Cabana Stripes Crib
Paper not feeding in order to print
make sure the input tray is properly setup and aligned, the tab is pushed against the paper.
Dec 12, 2008 | HP LaserJet 1018 Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Staples SPL-P100 calculator feed
Okay. Tried the other ways listed here, did not work.. BUT fold the paper into a point.. then feed through.. it worked the first time!!
Feb 10, 2008 | Canon P23-DH Calculator
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
HP DeskJet 722c InkJet Printer Logo
133 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
