Question about Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire washer model FTF2140ESO that wont begin any washing cycle after the start button is pushed, the only thing that happens is the door locks and then about 20 seconds latter it just beeps and the lights flash
I've had this happen before. Try unplugging it and leaving it unplugged for about five minutes. Plug in and try again.
Leslie
Posted on Oct 09, 2009
    Problem Solver:
  • 4 Answers
I have had same problem and it was the main control board
Posted on Oct 21, 2009
Why does the washer not begin any washing cycle?
Does water fill the tub after the first drain cycle on start up? Whether it does or not, you more than likely have a problem with the main "brain" or, controller. Try different cycles to see if any thing happens. If not , you most definitely need to replace the controller. This should be left up to a professional repair person. Or, if your mechanically inclined you could tackle the job yourself. Hope this helps.
Sep 11, 2014 | Frigidaire ATF6000ES Front Load Washer
Why wont my washer to perform the system clean cycle?
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
There is still water in my washing machine drum when it is done
Is your drain hose to far down the drain pipe?
Sometimes the water can cyphon back down into the machine if this is the case.
Jun 17, 2009 | Frigidaire FTF2140E King-Size ENERGY STAR
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Front load washer FTF2140FS
What is this a Speed Queen??? I need model & Serial Number.
May 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem with frigidaire washing machine
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Apr 15, 2007 | Frigidaire GLTF1240A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
795 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
