Question about HP LaserJet 3330 All-In-One Printer
Manual feed from upper tray copy produced line
Manual feed from upper tray copy produced with vertical line on page from top to bottom
  • 105 Answers
Vertical lines are caused by one of two things. 1. The photosensitive drum in the toner is scratched or the fuser has a problem. Either is an easy fix.
Posted on Oct 08, 2009
Black vertical line down the middle of my copies? This only happens when using the feeder.
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,
The Manual feed tray Uses A feed roller and a Seperation Pad
If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller
Instructions:-
open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .
close down the Service Hatch and return to machine -
You may need to run several pages through tray one before all tread marks Dissapear
Sep 13, 2013 | HP Color LaserJet 5500 Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My printed pages have a single vertical blackish/grey line
Hi johnpenglish,
This is a fairly common problem - it happens when some toner accidentally gets on one of the rollers that feeds the paper through the machine. This problem will often fix itself (i.e., once the loose toner has rubbed off on a few sheets of paper, it will not be on the roller anymore), but if you continue to have the problem, try using a damp cloth or paper towel to wipe off any loose toner on the rollers or the inside of the machine (you might need to remove the toner cartridge in order to reach parts of the feeding path. Be careful not to get the toner on your skin or clothing, since it stains.
Once you've gotten any loose toner off the rollers, you should no longer have a problem with lines in your copies. If the problem recurs frequently, it may be a sign of a defective toner cartridge (which releases more toner than it's supposed to).
I hope this helps - please let me know if I can be of any further assistance.
H2H
Dec 14, 2008 | HP LaserJet 3200se Printer
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
Lines on making copies
clean the glass of the scanning area, a small dot of debris on the glass produces a vertical line from top to bottom in the feeding direction of the laser printer.
May 07, 2008 | HP LaserJet 3055 All-In-One Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP LaserJet 3330 All-In-One Printer Logo
321 people viewed this question
Seeker5211
Seeker5211
