Modems i have broadband via cable. i have a wireless laptop. currently my modem is fixed in my bedroom which is where i can only use my laptop for internet access. i also have a desktop pc in the attic which is not connected to internt. my question is what type of router do i need to buy that will allow me use of both the laptop and my spare pc, without me having to move the modem!!!!!!!!!! please help
    Problem Solver:
  • 11 Answers
I would suggest a Belkin Wireless G or Pre-N router, hawkings is also good to use.
Hope this works.
Posted on Dec 25, 2007
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
How can i connect my desktop computer to the internet plz i need someone to help
Currently, the most common way to connect a desktop system to the internet, is by using the network jack to connect to a broadband cable modem or DSL modem. To do either you must have the service from either you cable provider or phone company (For DSL) and have the modem device for the service. Fees run $20 to $50 a month depending on speed you subscribe.
You connect the device to the system using a CAT5 network cable to a RJ45 (8 wire telephone type jack). Some Cable/DSL modems also have USB connection capability for the few systems these days that do not have a built in RJ45 connector To use them, you install the associated software, then connect the USB cable when prompted.
If you don't have Cable/DSL then dial up telephone modem is the next option, this requires a telephone modem that has an RJ11c telephone cord jack connection, most current computers only have a telephone modem as an option, but they can still be bought for around $20 and you will require a dial up internet service (Few remain, one is Netzero in the USA)
Mar 11, 2010 | Computers & Internet
Router not speaking to modem
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
Jun 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
You have to check if your computer can connect to the modem with an Ethernet cable. This will tell you if the ethernet port on the modem is working. if that does not work call your cable provider.
Next thing after you get the instructions above done.
Press the reset button on the back of the router> press it in for 30 seconds then let go and pull out the power. Connect the router up the way it should be before you reset by the way. check if you have internet if you do not follow hte directions at teh link below.
CABLE SETUP
If you need more info just message me
Aug 29, 2008 | Linksys Wireless-G Broadband Router
ACCESSING MY LINKSYS
Hi Sorry for the late reply.
Do you have a phone number I could call you on?
Thank you!
-Cameron Bradford
Also, you can visit my website www.pc-fix.us
Aug 19, 2008 | Linksys Wireless-G Broadband Router
WIFI
You can go for a wireless router, so that you can access internet anywhere in your house, ,
Jul 18, 2008 | Dell Inspiron 5100 Laptop
Wlan connection problem
please be specific, what exactly is happning???
Nov 07, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
64 people viewed this question
Alun Cox
David Payne
David Payne
