Question about Sony Playstation 3 (PS3) Console
PS3 turns off and red light flashes
My ps3 is on but when i press the on button it turns on for 3 seconds (flashes yellow) then beeps , then turns off and the red is flashing . whats the matter with it
Its over heated
Posted on Oct 07, 2009
3 Suggested Answers
SOURCE: wont turn on and red wont stop flashing
its overheated
DD1992
  • 122 Answers
SOURCE: ps3 80g light turns green flashes yellow, then
Unfortunatly your ps3 is dead, I am sorry for your loss.
Posted on Jul 13, 2010
I dropped my ps3 it works but when i turn it on the green light apperas then in two seconds i8t makes the reset noise then turns yellow then red. The red light then continues to flash. What do I do now
Hello
With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
Connect the controller using USB cable and press the PS button on the controller.
Now, the system restore screen will come up
You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
Good luck
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
How to fix ps3 when light flashes green,yellow, then red
Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.hello
regards
shaun
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Wont turn on
your ps3 is done. this is known as the yellow light of death.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
279 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
