Question about Kenmore Washing Machines
I have a Kenmore washer that has trouble agitating. I took off the cap on the agitator and tightened the bolt that goes into the agitator. This fixes the problem for a while. Pretty soon the agitator stops moving.This bolt doesn't stay tightened.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are two "bolts" for the agitators (assuming that you have the basic split system) The bottom agitator turns back and forth and the top section only turns one way.
The top section (when you remove the cap) usually has a plastic 1/2" square drive bolt.
If you remove the bolt and top section of the agitator, you should see a second 5/16" stud. under the stud is a rubber washer.
The first thing I'd do is pull both parts of the agitator and look at the splines inside of the lower agitator and the splines on the transmission agitator shaft. If either of them is worn / broken, your washer won't agitate. Also make sure that the two pronged "washer" is in place on the transmission agitator shaft and that the clip that holds it in place is fit.
If the splines are OK, I'd carefully put the lower agitator back on. Check the condition of the rubber washer on the stud. Install the stud and do not over-tighten.
Put the top agitator on tighten the 1/2" bolt carefully. Don't over-tighten.
Beyond that, you may be looking at a clutch or transmission problem.
Posted on Oct 07, 2009
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the...
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Kenmore 24972 Top Load Washer
The bottom part of the agitator will turn, but not the top part
The agitator has two parts. One is the bottom agitator and then you have the top agitator that moves the clothes around. If the top part of the agitator is not moving. You probably need to replace the dog ears. Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid. -- click on this link directly to get the detailed instruction for replacing dog ear
http://www.american-appliance.com/catalog/newsdesk_info.php?newsdesk_id=136
to remove the whole agitator check out the instructions as follows:
(1) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1, picture2.
(2) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator. also you can get the exact required parts from www.repairclinic.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 25, 2009 | Kenmore Washing Machines
Agitator bolt will not stay tightened after replacing agitatr cam
It sounds like the dogs are worn out. They are four ears that spread out and grab the sides of the top agiater and makes it spin in only one direction. It should free wheel in the other direction. It should not turn in both directions.
Did you replace the four dogs inside the agitator? Your model number shows that it takes one of two kits. This is the most common http://www.partselect.com/PartDetail.aspx?Inventory=334624&SourceCode=7&ModelNum=11022942100 Here is the other kit. http://www.partselect.com/PartDetail.aspx?Inventory=334655&SourceCode=7&ModelNum=11022942100 One of these should fix the problem. If you replaced this part, the threads must be bad where the bolt goes in. Every machine I have ever workd on had a 5/16 head bolt in the center so I have never broken one off myself. this would be new to me. This has either been changed in the past or I'm thinking of a differant part than you are. Good luck.
Nov 12, 2009 | Kenmore Washing Machines
Dual action kenmore 70 series washer need to remove agitator
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
How can one remove the agitator,it seems to move slower than it used to
If this a Whirpool manufactured washer (this includes Kenmore, Estate and Roper), the agitator can be removed by following these steps:
1, Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Some washers will have a fabric softener dispenser on the center post.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
If you have questions, or need additional assistance, please let me know.
NOTE: When reinstalling the agitator make sure you do not over-tigthen the bolt. This can damage the agitator and restrict its movement. Tighten until snug.
Jul 08, 2009 | Whirlpool WTW5500ST Top-Load Washer
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Mar 12, 2009 | Kenmore Washing Machines
Need to remove agitator on kenmore series 70
Follow these steps for removing the agitator on a Kenmore:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Sometimes this is a dispenser cup that simply pops off.
  4. Carefully remove the auger (upper portion of the agitator) and set aside.
  5. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
Note: Try to keep all the parts assembled while doing this. In particular, the auger. There are small components inside. In addition, when reinstalling the agitator DO NOT over-tighten the center nut. This can restrict agitator motion and may cause damage. Tighten until snug.
If you have questions, please let me know. I hope you find this information useful.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Model #82881110
Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
Oct 09, 2008 | Washing Machines
Washing Machines Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
