Question about SmartDisk FireLite 80 GB Hard Drive
When i hook up the smartdisk nothing happens - SmartDisk FireLite 80 GB Hard Drive
  • 3,153 Answers
We see a lot of problems on Fixya with these drives.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 07, 2009
When I plug it in My computer bings, the light on the drive comes on and then nothing else happens. I hear nothing from the drive either.
The USB slot of the hard drive become loose. Try solder it or purchase new Usb hard drive case to solve it.And your hard drive again start working
Sep 20, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
I have a new computer . Lost all my pics on the old computer. What do i do to get my pics off my smartdisk?
You should be able to install the hard drive to your new computer. And what happened to the old computer? Did your hard drive fail? You can take the hard drive out of it and change the pins to slave cylinder and hook it up to another computer and get the files off of it. You can even run scandisk on it and sometimes fix it enough to retrieve the files you want. then just copy them to your new one. If the hookups are different than new one, you might have to find a friend that has an old one like it.
May 17, 2010 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Hi. Years ago I bought a 160gb crossfire hard drive, but did not fit it up, so it has never been used. I am now trying to connect it up and get it working, but nothing happens. Model is USBXF 160, lot no...
Yes. It does need a power supply. I highly recommend not using this product It will work for a while and eventually not be recognized. This drive currently fried on me. If you chose to get rid of it let me know. I need the circuit board from this drive inorder to get files off my fried hard drive.
Jan 31, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Not showing any signs of power, and computer not seeing new hardw
Try using a different power cord because if there is no power nothing will happen on the computer
Dec 11, 2009 | SmartDisk FireLite 80 GB Hard Drive
Plug 80 gig Firelite into Mac, nothing happens.
Look up a harddrive/flash data recovery program on google. Run it it should find the files on it back those up then reformat the drive.
Sep 19, 2009 | SmartDisk FireLite 80 GB Hard Drive
I am attempting to hook up a iMac with Version 10 to a 250 Gb SmartDisk. The download refuses to load to the Mac Hardrive. Roger Heid rogheid@mac.com Tel 952 985 4139
Okay, do you know what the format of the hard drive is? Also, do you happen to know what system platform is running on that drive? Tell me if you don't know and I will see if I can walk you through it.
Aug 19, 2009 | Computers & Internet
Verbatim firelite external hard drive
ok...well...then if it is compatible with your current operating system, then it should work. is this a first time install?
Oct 13, 2008 | Verbatim SmartDisk Firelite Portable USB...
Smartdisk is giving me a device removal message
I am so upset with this H.D. it keeps on clicking on and off constantly. I don't think I can return it because I bought it on ebay. Someone please help me. My iTunes is all screwed up.
Mar 22, 2008 | SmartDisk (DHXF250F) 250 GB Hard Drive
SmartDisk FireLite 80 GB Hard Drive Logo
432 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
